Slot hole cutting
Slot hole cutting
Does anyone else have a hard time cutting the slot on the stem bit?
Any ideas on how to do this an easy way?
HELP!!
Robert
HELP!!
Robert
Ah Ha! A topic I clearly need to cover in the Pipe Making section.
This is indeed tricky, perhaps to the point of being the hardest thing to do well on a hand cut stem.
I'll write up my method in the pipe making section, and post back here when I'm done.
Good question.
Good question.
Random, I was using a Dremel high speed cutter #199. It just didn't give as clean a cut as I would like so I'm going to have to go to work on it with my tiny jewler's files to get things to look right. Here is a link to the cutter on Lowes website.
http://www.lowes.com/lkn?action=product ... 055929-199
I will try your method next time I attempt this task. Thanks!
Stephen
Carving Pipes in the Oldest Town in Texas.
Well, I don't know if it is clear or thorough enough, but here it is:
How to cut the slit
Let me know if it is helpful.
How to cut the slit
Oops! After creating that link, I changed the name of the file...moron move. Sorry!
It should work now. Here it is again:
http://tylerlanepipes.com/modules.php?n ... g_the_Slit
or so...jeff wrote:So, Tyler, you cut the slit about 1" deep into the stem?
Jeff
I probably need to clarify that slit will be a V shape. 1" from the bit the hole drilled through the rod will be untouched, and gradually from there taper open until the slit is about 3/8" wide at the bit.
