Been waiting for power for 11 months to get the machinery i got from Bo Nordh running. Now finaly i can start installing the machinery and start making again, visited Eltang for 4 days learning the machinery and made 2 pipes there, or 2 was completed.
finaly got my workshop running again
- smokepiper
Wow, beautiful work on these two pipes, Ronny!
I am very glad to hear that your new workshop is coming along and the equipment is now hooked up. I'm looking forward to seeing more of your pipes. it's great to see your up an running again!
Scott E. Thile
http://sethilepipes.com
Sysop: http://pipedia.org
- smokepiper
thank you!
I had access to Eltangs machinery with these pipes, he invited me for a quick run through the machinery i got from Bo. The stain is Eltangs famous contrast, lots of work but the result is stunning. If translated word by word it´s (brasschloride, natriumchlorat) second is (anilinhydrochloride) the first is blue colored fluid looks like mouthwash, second is transparent. When used the blue is making a yellow color to the wood and the transparent is making a reaction turning the wood pit black. [/img]
- smokepiper
I guess we all have our bright moments, it´s a stain so deep into the wood that i used 10 min polishing with red polishpaste and just freed some tiny spots from the pit black, then i used 400 grid to highlight the soft wood and finaly stained it with pure yellow alcohol stain. No fears of the green effect that other black stains bring when second stain is yellow. It´s just amazing and beautiful
All you have to do is translate to the common English chemical names, and you can find them very readily. They're typically not inexpensive, however. And in solution, they are treated as hazardous material, so it's best to find them in an anhydrous state.
You also have some chemical knowledge of what does which, and then figure out the concentration of each to put into solution.
As far as the same results? Probably not. However, there are similar results to be gained by using various acids (muriatic for one) and other metallic salts. On their own, the results are rather subtle, but you can amp them up with the addition of other compounds.
- smokepiper
when i look close to the names on the bottles it says brass(II)chloride, i guess it´s a important message. i apply the fluids twice each let it dry between applications when i added the second chemical i can hurry up the process with some heat but as eltang doing it he let em dry and after the last chemicals second time he let the pipe rest for 24 hours or more the longer the better. Hope you get this working for you and mind it´s quite dangerous chemicals not for mouthwash....
