Tools for rustication
LAG
Post by LAG »
What tools do you use to fine rustication?
http://s1375.photobucket.com/user/Lag2/ ... sort=3&o=0
To be or not to be... a pipe smoker. I am.
socrates
Re: Tools for rustication
Post by socrates »
I made a tool from finishing nails with the heads removed, 1/4" stainless tubing threaded at one end. Set as many nails as you can fit into the tube. With the sharpened end of nails protruding from the unthreaded end of tubing . Pack clay into that end and fill the other end with epoxy glue. After it sets up screw into stainless steel"t" fitting which makes a great handle.
jogilli
Post by jogilli »
Here a pic of one of my tools... The rest of a shank from a spade bit
James
LAG
Post by LAG »
James: how do you use your tool, with hand or on a drill ?
jogilli
Post by jogilli »
With my hand... Simple twisting action... Just don't over think the process ....I usually go over it a few times until I get the results I want
LAG
Post by LAG »
Thanks !
