That means that when somebody would like "to peek into his workshop", aka learn/ask something - he turns silent.Frank wrote:What the heck does that mean?tritrek wrote:.... but rather ignorant to the peeking questions
Pipe Atelier Yashtylov - Handmade Pipes from Russia
In my work there are no secrets. But I very badly know English language. I am afraid, that my explanations will be deformed from for bad knowledge of language and it will turn out very badly. My translator not always correctly translates your texts, and I cannot sometimes understand questions. And time not always suffices......tritrek wrote:That means that when somebody would like "to peek into his workshop", aka learn/ask something - he turns silent.Frank wrote:What the heck does that mean?tritrek wrote:.... but rather ignorant to the peeking questions
I have many suppliers, but I give preference to several Italian suppliers. And as drilled an aperture I can not tell, could show, but we far apartTano wrote:Two questions that I don't thik anyone has asked. The briar is very nice, who is the supplier? The beautifull calabash, how was the air hole drilled to follow such a curve?
Sorry, that was not meant to insult you in any way - online to "wake you up" and it seems I was successful
I'm sure we will be able to understand your messages, we are here to communicate after all. Your pipes are amazing, stunning! I think we all are eager to see a little of the "master at work"
I am not offended:), it is a pity to me, that my knowledge of language do not allow me to communicate with you is high-grade. As I very much огорчаюсь that my electronic translator cannot do(make) translation of technical subtleties and nuances.... Though I also am very strongly busy, in the future, I shall try to answer your questions maximum quickly.
огорчаюсь means something like "it annoys me" or "it bugs me". No online translator finds it only if you cut it to огорча
Unfortunately I don't speak Russian but many of my collegues do
Small lesson of Russian:)tritrek wrote:огорчаюсь means something like "it annoys me" or "it bugs me". No online translator finds it only if you cut it to огорча
огорчаюсь - I am upset, I suffer
Strange, my translator does not want to translate this word.... Therefore I used synonyms of this word
Good day to you,
Maybe we can start a dialogue that can be answered in "yes" or "no".
For example, when you drilled the air hole in the calabash, did you use a straight drill bit? If "no" did you use a special bit that we are not familiar with? Did you drill the hole with a power tool or by hand?
Maybe some of the other masters can help with this procedure.
Great work!!
Great work!!
All the best,
Tano
Tano
In a pumpkin I have cleared the air chamber in a management(manual) by means of training the big diameter and dremel and also knifes and a scalpel:) under various cornersTano wrote:Good day to you,
Great work!!
The aperture in direct чубуке. Under very sharp corner.
Has overlooked... - the Scalpel should be bent
- ToddJohnson
I'm not sure how Mr. Yashtylov does this exactly, but a "pumpkin" aka gourd-Calabash is typically done this way: The tobacco chamber is drilled to a standard size--say +/- 3/4". The draft hole is then drilled as deep as possible with a standard straight bit. At this point, the two will not intersect. Then, by whatever means one feels most comfortable--rotary burs, small gouges, etc.--the tobacco chamber is hollowed out and brought to a tapered/funneled point. The funnel, however, follows the lines of the bowl, inching back toward the draft hole. Eventually, the two intersect. At that point, the bowl is more thoroughly hollowed out and smoothed to act as an expansion chamber which will accept the turned "bowl." The turned bowl sits inside the expansion chamber and there is basically a hollow chasm underneath it. The bowl is removable and held snugly in place via a compression fit using a small ring of cork or rubber around the turned bowl. This is an extremely advanced endeavor and requires a great deal of precision and control. Not for the faint of heart to be sure.PipeAtelierYashtylov wrote:In a pumpkin I have cleared the air chamber in a management(manual) by means of training the big diameter and dremel and also knifes and a scalpel:) under various cornersTano wrote:Good day to you,
Great work!!
Now I know! That is simply amazing! When I see it on that picture, the principle looks pretty simple, however making must be truly hard.
pennsyscot wrote:Mr. Yashtylov, I think you are a very talented pipemaker. This pipe is beautiful. Could you please describe the products and process used to achieve this finish. thank you, Scot
Forgive, I have not understood your question.... My electronic translator does not consult. Try to paraphrase a question
