Shaping this type stummel
How is this type stummel shape accomplished, especially the front portion? Are there special tools used?
- 002-354-0170_2.jpg (104.82 KiB) Viewed 4062 times
Re: Shaping this type stummel
This can be done by just about anything. Probably the quickest is to use a sanding disc. You can also use carving knives or chisels or files and rasps. A dremel with various bits would work as well. If I want to shape something unique, I will go to a local woodworking store and look at the different tools and bits and think about which ones will work for my particular needs. For some specialized work, pipe makers will create or modify their own tooling.
Fastest is by disk. Gouges can be used too.
Andrew
www.andrewstaplespipes.com
There was a thread on here a while back about shaping a blowfish. An elephant's foot/shield is basically just a blowfish with the shank turned 90 degrees.
Ryan Richardson
R2 Pipes/Ryan's Luxury Goods
Woodchuck or Woodpecker are the best options.
Or you could use Files, dremel, sanding disk, belt sander, sandpaper, gouge, etc...
It is just sculpting by hand no matter what tool you use.
I guess a multi axis cnc mill would work too if you got a couple hundred thousand to blow.
I am gonna start saving for the cnc mill today.
Okay, were you joking about the woodchuck and woodpecker or did you mean the Woodchuck Power Taper Tool?
Woodchuck:
Woodpecker:
Woodpecker:
Ryan Richardson
How much wood can a woodchuck chuck if a woodchuck could chuck wood?
You had to go there.PremalChheda wrote:How much wood can a woodchuck chuck if a woodchuck could chuck wood?
Andrew
Give Premal a break Andrew.... this is what he got instead of a personality.
I dont understand how you would use the "woodchuck" to help shape the pipe.
A beaver would work in a pinch...when the woodchuck can't chuck wood.
For a complicated shape like this, I usually give viagra to rats and tie sandpaper to their peckers. A little rat pheromone on the parts you want sanded and you can sit back with a nice cigar, they do all the work.
Ryan Alden
http://www.aldenpipes.com
You dare enslave the mighty rat? LET MY PEOPLE GO!!!
Ryan Richardson
If you could see the smile on their little faces, you'd change your tune.Ratimus wrote:You dare enslave the mighty rat? LET MY PEOPLE GO!!!
Ryan Alden
A lot of training and feed it grubs often.JDwood wrote:I dont understand how you would use the "woodchuck" to help shape the pipe.
Who made the pipe in the original pic?
(I think i'm a little bit in love....)
J.D.,
Just in case.. We are joking about the woodpecker and woodchuck.
To make any shape, you can use any handtools, disc sander, belt sander, or hand held rotary tool. It is your hands that make the shape. Not the tool. The tool only assists you.
Whew! That's great, because I left my woodchuck out in the shop this weekend and it got too hot...PremalChheda wrote:J.D.,
