There is plenty of room, and you are most welcome. You are in!Bniesen wrote:I'm in if there is room, i'll get started this weekend.
PITH 2017!!!!!!!
- mightysmurf8201
Re: PITH 2017!!!!!!!
- mightysmurf8201
I concur. The PITH is intended to be a part of one's journey towards mastering the skill of pipe making. I prefer we don't set any precedents that can be exploited down the road, i.e. offloading pipes that won't sell, and such. Not accusing anyone of anything, and it hasn't happened yet that I know of, just thinking ahead. Kinda my job to steer this crazy bus in the right direction.PremalChheda wrote:Take your time and make one the best you can. This is a good exercise for the experienced to guide and the novice to learn while in the process of making. I'm not so sure of providing a pipe that was already made. I would like to see participation regardless of skill level.themanredbeard wrote:I'm in if it's still open. I'll get an oval shank made asap. (I also still have one left from Chicago so...)
I'm going to have to withdraw from this year's PITH. To make a long story short, I have moved back to the USA from China, and haven't had the time or space to make pipes.
Good luck everyone, and I look forward to seeing your completed pipes!
Kiel
Kiel
Where at in the USA?kamkiel wrote:I'm going to have to withdraw from this year's PITH. To make a long story short, I have moved back to the USA from China, and haven't had the time or space to make pipes.
Kiel
I am right near the Wisconsin border in a town called Richmond.PremalChheda wrote:Where at in the USA?kamkiel wrote:I'm going to have to withdraw from this year's PITH. To make a long story short, I have moved back to the USA from China, and haven't had the time or space to make pipes.
Kiel
- Rbraniganpipes
Hey guys and gals,
I am hoping to be able to get my pipe done in time. Do we have a specific date in mind for when we would like to do the exchange?
I haven't had a lot of time in the shop lately, as over the last month I changed jobs, planned a wedding, and got married. All of these things have limited my time in the shop. I am hoping to have a nice pipe done in time to participate, but may have to back out if I can't get it done in time.
R.Branigan Pipes
Hey welcome back, I hope it was a positive change.kamkiel wrote:I am right near the Wisconsin border in a town called Richmond.PremalChheda wrote:Where at in the USA?kamkiel wrote:I'm going to have to withdraw from this year's PITH. To make a long story short, I have moved back to the USA from China, and haven't had the time or space to make pipes.
Kiel
- mightysmurf8201
We're aiming for the end of July.Rbraniganpipes wrote:Hey guys and gals,
- BriarShrink
Premal and others. Still working through attempts at a good oval shank. Learning a lot...but haven't completed one yet. I figured I would post this here. If I'm looking to use files as suggested, what kinds would you suggest? Pics helpful too. I've used a rough file/rasp to shape as well as a 100 grit emery board. Thanks, Tom CobbPremalChheda wrote:Take your time and make one the best you can. This is a good exercise for the experienced to guide and the novice to learn while in the process of making. I'm not so sure of providing a pipe that was already made. I would like to see participation regardless of skill level.themanredbeard wrote:I'm in if it's still open. I'll get an oval shank made asap. (I also still have one left from Chicago so...)
Sent from my SAMSUNG-SM-N910A using Tapatalk
"I have some friends, some honest friends, and honest friends are few; My pipe of briar, my open fire, A book that's not too new." ~ Robert W. Service
I'm going to have to drop out... again...
Building a new workshop has taken up soo much time that I haven't finished a pipe in months, and I've got 4 pipes in progress, all spoken for, none of which have an oval shank :p
Turn oversized a little more than what you want the end of the shank to end up at.BriarShrink wrote:Premal and others. Still working through attempts at a good oval shank. Learning a lot...but haven't completed one yet. I figured I would post this here. If I'm looking to use files as suggested, what kinds would you suggest? Pics helpful too. I've used a rough file/rasp to shape as well as a 100 grit emery board. Thanks, Tom CobbPremalChheda wrote:Take your time and make one the best you can. This is a good exercise for the experienced to guide and the novice to learn while in the process of making. I'm not so sure of providing a pipe that was already made. I would like to see participation regardless of skill level.themanredbeard wrote:I'm in if it's still open. I'll get an oval shank made asap. (I also still have one left from Chicago so...)
Draw an oval on face then shape down just by the end of the shank.
If you are skilled with disk or belt grind corners to blend where bowl meets keeping a small taper. Bottom line needs to be precise and you can have a bit of a flat if you want it to sit perfect.
Before you go to a wide flat file, get the stem on and match close or even a little smaller than end of shank.
File at about a 45 degree angle from stem to bowl and under bowl keeping very steady hand controls .
When you have it all matched up to drawing flip 180 and match. Check for diagnosis corners being even then fix flip and match again. Should be as close as possible after this if done properly. When sanding you have to keep memory of how much you sand each flip.
Also use something wide and flat like a file to wrap sandpaper around.
There is more to it but it is instinctual procedures that vary person to person and depending on tools and methods.
- BriarShrink
Thanks again Premal. Getting closer.
To add to Premal's advice, I use a 1/4" Delrin tenon for Canadians and such. This will give you a stronger tenon and a bit more wiggle room while shaping the shank.
IAWDDocAitch wrote:To add to Premal's advice, I use a 1/4" Delrin tenon for Canadians and such. This will give you a stronger tenon and a bit more wiggle room while shaping the shank.
- Vermont Freehand
a quick polish and bowl coat and my entry is ready
Please add Robert Vacher to the list. He is waiting on his account to pmf to get confirmed by Tyler so he can't post at the moment
- PeskyPrussian
Pipe is finished and ready for the hat!
Question regarding the swapping and critiquing procedure:
Whenever I complete a pipe (at least at this point) I perform as thorough a self-critique as possible, recording every little aesthetic or functional detail that I can improve upon the next time. My initial impression would be to provide this self critique along with the PITH pipe when we perform the swaps, as some people do when they post their stuff to the gallery. I feel like providing a self critique on an online forum helps to orient reviewers to what the maker does or doesn't see so they know what level of critique to provide.
However, someone brought up a good point on the facebook side of the forum that perhaps providing a self critique in a situation like this is not conducive to an independent review. It might color the impression or cast the discussion in a direction that the critic wouldn't otherwise go. Anyone have any opinions regarding this or any other considerations about the pipe swapping?
Thanks!
Thanks!
Adam Bybee
bybee_pipes - instagram
My pipe is done and ready for an address to send it to. PeskyPrussian, good points I am curious about this myself.
Either way it works. It is what you are most comfortable with.PeskyPrussian wrote:Pipe is finished and ready for the hat!
Thanks!
