New Metal Lathe
- CTMachinist
Cummins chuck
CTMachinist
I just got my Cummins lathe. I noticed that the hole in the center of the chuck is NOT 3/4" dia. Is it possible to open it uo to 3/4". I didn't measure it but, I did try to put a 3/4" rod thru it and that's how I noticed it was small.
Cummins lath
Gary did you bore yours out to 13/16"? If so how did you do it?
I wanted to use my lathe for turning the tennons on pre-made bits but, all of the one I have are too wide to fit comfortably in my chuck. I need to go well past the jaws in order to hold the bit tightly in order to turn it.
My lathe came with the larger hole thru the spindle - easily passes a 3/4" diameter rod. It is a Harbor Freight model 93212 as opposed to the older 33684 lathe. Same basic machine with a few differences. Such as safety guards with switches and a cover or the lead screw. They did cheapen the half nut design and mine broke. I replaced it with the half nuts from the 33684. Cuts threads as it should now.
You can purchase a couple of different collet systems that will hold stock up to 3/4" diameter. Littlemachineshop.com has #3 Morse taper collets as well as ER-32 collets. The 3MT collets use a draw bar from the back of the spindle to tighten the collet. The ER-32 can be used similarly or with a collet chuck that allows you to put the work through the spindle while it is held in the collet.
Buying a lathe is just the beginning. The tooling and accessories will cost more than the lathe. I purchased the mini-lathe and mini-mill late last year. I have made a couple pipes with them but spend most of my time and lunch money making tooling for both machines. I am currently working on a collet holder to fit the 5C collets. These collets are available in 1/16” to 1-1/8” diameter plus several sizes of hex and square. Keeps me busy and off the streets.
Update - Checked the through hole diameter 25MAY06. It is 13/16"
Gary
- LexKY_Pipe
Metal lathe for pipes
Craig, are you using woodworking tools or the tool post and cutting tools that are common to the lathe to cut the briar? I have a 10" Atlas with a 54" bed and a South Bend 9" with a 24" bed and wish to use them but have not tried as yet. I need advice please. Thanks.
Bob Moorman
The Little Old (Novice) Pipemaker From Texas
- LexKY_Pipe
