ArtGuy wrote:Actually I started to hand cut my stems once Tyler told me that he would no longer return my calls until I started to do so
Probably the single most helpful thing I ever did for you!
Ah, I see. I agree completely. That's why I only use them on my "budget" grade of pipes.Tyler wrote: FWIW, "second class" was my term that I believe characterized the comments on the other board. I did not mean it as a derisive term, but in exactly the way you went on to characterize your lower grade of pipes. Some folks view preformed stems as only acceptable on a lower grade, "second class" of pipe. "Second class" not as an insulting term, but a literal description.
Being a theist that believes the Genesis account, and one who handcuts stems, I have no difficulty answering either the chicken OR the pipe question.hazmat wrote:that's almost a "what came first?" kinda question, Tyler.. lol...
In that line of thought, is a pipe made with a wood lathe, or one where hand chizels are used more hand made than one made on a metal lathe? Or doe the fact that we use tools at all impact the "hand-made-ness" of a pipe?Another thought: there are really only two parts to a pipe, stummel and stem. If you are handmaking only one of the two, is the pipe really handmade?
I don't see how my line of thinking leads where you suggest at all. It is not an issue of using tools, it is an issue of automation. If the stummels I received were pre-shaped and/or drilled on a fraising machine, I would not call my pipes handmade (even if I modified the shape a bit). My question is simply why does that not apply to the other half of the pipe?Nick wrote:In that line of thought, is a pipe made with a wood lathe, or one where hand chizels are used more hand made than one made on a metal lathe? Or doe the fact that we use tools at all impact the "hand-made-ness" of a pipe?Another thought: there are really only two parts to a pipe, stummel and stem. If you are handmaking only one of the two, is the pipe really handmade?
Jim didn't make the components he mixed though. The issue is not whether you make or create the raw materials. In the case of pipes all that we are doing is shaping. Did you shape it or not?Unless we're scratching the briar with our fingernails, (I'm sure my toe nails could put a dent in briar, but YUCK! The after taste might be an issue there.) none of our pipes are really hand made. We use tools. And the preformed stems simply come from another tool manipulated by another worker. I think you could argue that someone like Jim Cook who casts his own preformed stems are more hand made than the ones we buy from shops, but not by much. They're just made by the same person who is making the stumel.
That being the case, why does my question bother you? (Perhaps I am reading you wrongly, but you seem a little irritated by what my question might imply. I am not trying to be offensive, BTW. I was simply struck by that question as I finished a post, so I asked the question to you guys. I suppose I am "thinking out loud.")Anyway, hand made pipes are a myth. Hand made anything is pretty much a myth.
I don't know how you procreate, but I CERTAINLY don't do it with my HANDS! 8OWe simply accept that the use of tools goes into any product (save the act of procreation, and even then, some tools can be used. Hehehehe). It seems the more people interact with the product, the greater the degree of hand-made-ness.
Tyler, you raise an excellent point. When I was very early in my carving adventures, around my third or fourth pipe, I was thinking that I would just use premade stems. Paul Tatum asked me if I wanted to stick premade stems onto stummels, or did I want to make pipes? That question has always stuck with me. I am also glad that Paul asked it to me in that manner, as it gave me the push I needed to begin making stems from rod.Tyler wrote:Another thought: there are really only two parts to a pipe, stummel and stem. If you are handmaking only one of the two, is the pipe really handmade?
FWIW, I have always been of the opinion that if my hands are in control of the tool as it shapes the pipe/stem, or if my hands are in control of the pipe/stem as I hold it against a spinning disc or belt, then it is handmade.Nick wrote:[In that line of thought, is a pipe made with a wood lathe, or one where hand chizels are used more hand made than one made on a metal lathe? Or doe the fact that we use tools at all impact the "hand-made-ness" of a pipe?
