Finished This Morning
Here's a standard type shape that I finished up this morning. The stem is lucite and the stummel features a delrin mortise lining. It's on the way to its new owner even as we speak (at least it is if the post is moving).
Joel
Joel
Or you could say, VERY nice work! That's an extremely comfortable looking pipe; there's a lot to be said for traditional shapes --- especially when they're done so elegantly.
-- john
http://justapipe.com
Nick, I prefer a delrin sleeve over a tenon. The reason is that if a pipe is dropped (with a delrin tenon) then the shank is more likely to break. With a delrin sleeve, the stem is more likely to break. Easier to replace the stem and, since the shank won't need to be banded, the pipe looks the same as it did when purchased.
I'll use the mortise lining when the shank is thick enough to permit it. With a thin shank pipe, that's not going to work.
You know, I've read this a lot of places, but have never really seen any sort of evidence to show that it's the case. I've dropped a lot of pipes over the years, even had some fly out my hands at high speed, and I've got to say that my experience doesn't reflect the assertion that delrin tenons will destroy shanks when dropped.JSPipes wrote:Nick, I prefer a delrin sleeve over a tenon. The reason is that if a pipe is dropped (with a delrin tenon) then the shank is more likely to break. With a delrin sleeve, the stem is more likely to break. Easier to replace the stem and, since the shank won't need to be banded, the pipe looks the same as it did when purchased.
Not saying it's wrong, just that my experience doesn't support it.
Kurt, my experience is a little different I guess. I've dropped a few pipes and a couple in particular kept breaking. The stem broke anyway. They had a delrin mortise lining and the stems proved very easy to replace.
Delrin is tough stuff. Whether my assumption is true or not is open to interpretation, unless someone wants to test it. I don't have the measuring equipment for that!
