Just want to introduce my 1st "selfemade" pipe after my visit at Rainer Barbi (without a little help of my friend )
Dimensions:
Length: 170 mm, Stem: 70 mm
Hight: 48 mm
Bowl width: 48 mm
Bowl length: 56 mm
Tobacco chamber: 22 x 40 mm
Weight: 62 g
Shank: 14 mm width, 16 mm hight at the shank/stem junktion
Stem: Epoxyd, Bernsteinimitate, oFi
Some words to the stem: Epoxyd is similar to Acryl, but it seems to be softer. It's easy to drill, easy to shape and also easy to polish! It's a little bit transparent you can see the cleaner goimg through. In earlier posts was a question about transparent stem material - I bought it from Marco Janzen as rodware. He's a lot of new rod material... http://www.janzen-pfeifen.de
HGD-Pipe #24
- staffwalker
Hi Steve,
the bottom of the tobacco chamber is an "U" as usuall... I think I'd a little trouble with the light while taking the pics? And the angle is a little bit to the left (in the pic). As example you can't see the airway.
Sorry guys, but I'm still trying to learn to make better pipe pics.
Greetings from Germany,
Heinz_D
Heinz_D
