So, I'm setting up a rather small workshop in the basement. It's only a temporary setup until I can turn part of my garage into a heated workshop. For now, I'm going to enclose the area in with plastic vapor barrier sheeting dropped down from the ceiling to the floor. This is to prevent the dust I create from making it's way to the furnace.
To futher reduce the dust I was thinking about creating a makeshift airborne dust collector and wanted to have some opinions on if it would work. I would use this in conjunction with a localized dust collector using a shop vac. Also, I'm using a respirator...so no worried there...it's mainly for preventing the dust from making it's way to other parts of my house.
Here's what I'm thinking of:
I'm trying to save money and that is why I'd like to do something like this as opposed to buying a manufactured dust collector right now. I figure this will cost me less than $50 to make. The area is only 12x12.Airborne dust filter
To reduce airborne free-floating dust, I employed a trick which I saw recently in a home improvement magazine. I took a normal household box fan, and attached a furnace filter onto the intake side of the fan. I took the plastic grill off the intake side of the fan and reattached it with spacers and longer screws, allowing me to simply slide the furnace filter into the slot. It works quite effectively, producing a nice brown circle on the filter in no time at all. This is good, showing dust that is not getting inhaled or settling on everything else.
Anyone else try something like this?
