sandblasting equipment
The best vac system I've found is to use a shop-vac, but put a cyclone separator between it and the cabinet. That way most of the media goes into the intermediate can for reclamation, and the wood dust goes into the shop-vac for disposal. I also *really* love the shop-vac bags designed for sucking up drywall dust. Not only do they capture the dust for easy removal, but they significantly extend the life of the cartridge filter.
Briarfox
Post by Briarfox »
Thanks a ton guys. I've been using the blaster for about a year with glass bead and I end up with glass bead all over the shop. I'll try the shop vac method.
Which cyclone separator do you recommend for a shop vac?
Chris Houser
-Houser Handmade-
http://www.houserhandmadepipes.com/
jeff
Post by jeff »
I bought a vacuum made for blasting through Cyclone. They're pretty inexpensive at ~$150 and will save your shopvac motor from burning out when the media eventually makes it through the filter.
jeff
Post by jeff »
It's gone up since last year and is now priced at $190, but it's worth the money. Check it out here:
http://www.mytoolstore.com/cyclone/dustcol.html#dc1500
Briarfox wrote:Thanks a ton guys. I've been using the blaster for about a year with glass bead and I end up with glass bead all over the shop. I'll try the shop vac method.
Ideally you should be using the bottom two units on the page that Jeff linked to. However, I get very good results by using one of these:
http://www.pennstateind.com/store/DCLID12.html
In conjunction with a 5HP dust collector equipped with drywall bag and cartridge filter:
http://www.shopvac.com/detail.asp?id=165
FredS
Post by FredS »
If you're a DIY type of guy, Bill Pentz's website has all the info you could ever want about building a cyclone dust seperator.
There are also a bunch of plans on the web similar to this one for a pre-seperator built on a trash can or 5 gal bucket. But for the money/time investment, the Penn State Industries unit in Kurts link that fits on a 5 gal bucket is hard to beat.
Briarfox
Post by Briarfox »
Well guys it made a world of difference! No leaking glass bead! And it is a much nicer looking blast (Also got a new compressor). Thanks a ton. As always you guys are very helpful.
Chris Houser
-Houser Handmade-
