dremel tool to cut the V shape on a mouthpiece
ND Pipes
Re: dremel tool to cut the V shape on a mouthpiece
Post by ND Pipes »
i live in Croatia... :) so, i will look for those files....
thnx....
link is great btw... :)
http://tnd-pipes.com/
Dixie_piper
Post by Dixie_piper »
I got my needle files on ebay, shipped from China or Japan, they ship to anywhere, and they're like $10 US, if I remember right.
Adam
Veo Vendice
Deum Timete
(family motto)
eder
Post by eder »
From Germany:
http://www.fine-tools.com/feile4.htm
That's my main supplier for fine stuffs! Actually; from very weird stuff to usual thing...
Kind of things I like :nuts:
Pipes of inspiration...
by Eder Mathias
http://mrhydepipes.com
ND Pipes
Post by ND Pipes »
Eder, my man!!!!! that is what i was searching for regarding needle files...
items no.302708 and 302709... to be kind of oval on the sides... thanks for this link...!
hebi
Post by hebi »
my tools for making V-shape
figure
i just drilling 3 holes with 1.5mm bit on my lathe (black on figure) - center and V shape
and remove ebonite between holes with milling cutter and 1.5mm bit with my proxxon FBS 240/E
form an inner shape with diamond needle and sandpaper on metal pattern (right upper on photo)
voila:
ND Pipes
Post by ND Pipes »
hebi - thanks for these nice pic's.... and info too...
cutting by hand and using dremel tool was a bit of a problem to me...
allways wanted to get it nice and clean with less being worried about the outcome........ :)
thank You...
Abi Natur
Post by Abi Natur »
That is a beautifully detailed post hebi and a great result!
http://www.canaanpipes.com/
hebi
Post by hebi »
tNd wrote:allways wanted to get it nice and clean with less being worried about the outcome........ :)
and that's right
on upper photo - my homemade wood "vise" :)
i clamp the rod, place vise instead of QCTP on my lathe and drill holes turning the vise to the right angle
then i mill mouthpiece bite with dremel milling bits (left on photo)
ND Pipes
Post by ND Pipes »
the result is really perfect....
thank You for sharing...
I have one of Eder's pipes, so I can tell you...whatever he's doing works pretty dern good. The pipe smokes like a dream.
LAH
Post by LAH »
This is a great thread. Thanks for all the info guys.
ND Pipes
Post by ND Pipes »
JMG wrote:I have one of Eder's pipes, so I can tell you...whatever he's doing works pretty dern good. The pipe smokes like a dream.
I am proud to say that Eder is my friend :).. i have been looking at his work for some time for inspiration and learning... he really is a darn good pipemaker... :)
i value his opinion a lot.... so, i think that i will buy few things from the link he provided - they have few preety nice files there - just the medicine i was looking for....
geigerpipes
Post by geigerpipes »
Another tip for cutting the v slot with a drill bit try using something with a slower rpm than 15000 (witch atually burns away the ebonite) like a cordless drill or your lathe gives a lot more controll. I cut the slit with a corless armed with an 1,8mm bit, it takes a minute and after that i just touch it up with file total time to cut the slit is around 3 min and always perfect results
Smoke in peace!!
Love
Webpage www.geigerpipes.com
News/Blog http://news.geigerpipes.com/
ND Pipes
Post by ND Pipes »
Thank You for your reply... do You hold the mouthpiece in your hands while cutting the slot or You use some kind of jig....
geigerpipes
I have the rod secured in a vise and hold the cordless in my hand with the other hand steadying it
Smoke in peace!!
Love
ND Pipes
Post by ND Pipes »
thank you :)
regards
RadDavis
Post by RadDavis »
geigerpipes wrote:Another tip for cutting the v slot with a drill bit try using something with a slower rpm than 15000 (witch atually burns away the ebonite) like a cordless drill or your lathe gives a lot more controll. I cut the slit with a corless armed with an 1,8mm bit, it takes a minute and after that i just touch it up with file total time to cut the slit is around 3 min and always perfect results
I do the same thing, Love, only with my variable speed Dremel set on the first setting. You get no torque at the lower rpm, but you don't need it.
geigerpipes
Rad, I like the cordless better a dremel starts at 10000 rpm at the lowest setting my cordless starts at 0-500 rpm at the low setting with plenty of torque but whaterver gets the job done
Smoke in peace!!
Love
If you're having trouble getting a clean V slot using a 1/16" bit, try using a 3/64" bit. Since I started using a 3/64" bit on the low setting on my Dremel I've been getting much cleaner and thinner results.
