Hello Everyone,
I have enjoyed reading the post on this site. No other site comes close to the information listed here. I decided to join and post a few photo's of my my first briar pipe. This is my 3rd pipe. The first two I made from oak firewood I had lying around. This pipe has become my daily smoker. I have thick skin so all comments are very welcome.
My Egg Pipe
Re: My Egg Pipe
For a third pipe, and the first in briar, this shows great promise. Well done!
I would bend the stem less, and get a little more fluid with the profile lines. I'm looking forward to seeing your next pipe!
Re: My Egg Pipe
Very nice pipe you have made there.
Re: My Egg Pipe
Very nice! I agree with Kurt's comment about the curve though. I'd consider heating closer to the stummel first and get a longer, but more gentle bend going vs all of it being on the rear 1/3.
Re: My Egg Pipe
Do you mind sharing with me how you executed that inlay? Very nice pipe. I'm new as well so any critique from me would be of no worth.
Thanks.
Vid Trent.
Thanks.
Vid Trent.
Re: My Egg Pipe
hawky454 wrote:Do you mind sharing with me how you executed that inlay? Very nice pipe. I'm new as well so any critique from me would be of no worth.
Thanks.
Vid Trent.
I drilled a small hole, glued in a small piece of briar, sand and polish that's about it.
Wallaby
Re: My Egg Pipe
Wallaby
I guess my question is how do you get a perfectly sized round piece of briar drilled out to place in the hole you drilled in the stem? What tool would you use for that? I tried a hole puncher but I couldn't get that to work....HARDY HAR HAR!
Re: My Egg Pipe
Sorry, I understand now.....I cut off a small piece of briar, chucked it up in my drill press and used a file to begin a round shape and then used 220 grit sandpaper to get the correct diameter. Cut it longer than the depth of the hole, glue it in, sand the surface when shaping the stem. That's how I did it. This procedure is fast and only requires a few simple tools.hawky454 wrote:Wallaby wrote:
Wallaby
My pipe making skill level is nowhere near the level as most of the good people on this site. Taking direction from a noob probably should be taken with caution. With that being said, If asked, I will comment on what I might have done but to give advise would be wrong.
Wallaby
Re: My Egg Pipe
Thanks Wallaby. Sometimes us new guys can help each other out too. I'll give that a try.
- HumblePipe
Re: My Egg Pipe
Nice looking pipe, I love color and the dot inlay. Great work!
