What epoxy glue to use??? HELP NEEDED!!!
So far i was using a UHU plus endfest 300... it is 300kg/cm2 epoxy 2 components glue... it was o.k. until yesterday i found out that one of my pipes snapped on a shank extension even if i had a plug inside... so, i don't trust the glue anymore...
can somebody please tell me what is the best epoxy glue to use... (i can't remember one i was reading long time ago - some guys were talking about that glue... an industrial one or something - not sure) ... i need a glue i can trust with...
PLEASE HELP...
regards
daniel
PLEASE HELP...
regards
daniel
Re: What epoxy glue to use??? HELP NEEDED!!!
Hi Daniel,
at the moment I use the 2-component glue of Janzen http://www.janzen-pfeifen.de/frameset.html. I cannot say whether is better, but it is in the pipe construction already very long in use. I had up to now no problems with it, however, it frees itself at high temperatures (stem bend), but many make this.
Peter
Peter
Pipe-Blog: http://daskunstportal.at/artofbriar/
Drawing-Blog: http://daskunstportal.at/8bar/
Forum: http://www.daskunstportal.at/pipemaker/index.php
I use T-88 and haven't had any failures with it to date. You can get it at woodcraft.com.
wdteipen wrote:I use T-88 and haven't had any failures with it to date. You can get it at woodcraft.com.
that's the one i could not remember the name ... T-88.... will try to get it... i have seen some pipemakers use it but just could not remember the name... Thank you Wayne....
Peter - Janzen .. hmmm... will think about it also... i might go for T-88 in either way because i have seen that guys like to use it (read: it is reliable) ... i don't know about Janzen glue... will have to check...
guys - thank you...
regards
Help needed again... it seems to me that System Three T88 Epoxy Resin can't be shipped over seas... i am in Europe and i was searching for a company that has it here... dealers in Europe from System Three seem not to have it... can somebody reccomend me where to find T88 here in Europe....???????
regards
daniel
regards
daniel
I am using this product from ebay UK 370535352407. It works well but does not like to be heated, as when doing contrast staining.
Somewhere on here is a link placed by Walle for a German glue company that he buys from, you might want to search for it or send him a pm.
David.
David.
DMI - thanks for the info - i will ask Walle directly...
i really need something dead sure and dead reliable.....
thanks...
thanks...
Hi,
Regards, Jens
Here: viewtopic.php?f=18&t=5697&p=49172&hilit=glue#p49172DMI wrote:Somewhere on here is a link placed by Walle for a German glue company that he buys from, you might want to search for it or send him a pm.
Regards, Jens
Thanks Jos - it seems that i might be able to get T88 afterall... i am in the middle of arrangements with them ... will see...
i also got a message from Walle with his answer regarding Starbond .... thanks guys...
- oklahoma red
Consider a glue in the urethane family. Sold here in the states as "Gorilla Glue" as well as other brand names. This stuff will glue almost anything.
Charles
Charles
thanks
regards
regards
You didn't mention what materials you are bonding.
If you are bonding wood-to-wood, I would use Titebond III. If bonding dis-similar materials, epoxy is used by a lot of folks.
Kim Kendall
http://www.PenguinBriar.com/
i need epoxy...
the problem with glue is solved - thank you guys and best regards
daniel
daniel
