Ebay Briar
Ebay Briar
A halfmoon from Samantha on Ebay. Looks really good.
Re: Ebay Briar
Sasquatch votes for a big hunting horn from that block.
Re: Ebay Briar
I'm thinking this semi-bent, and a big oom paul. I like the horn idea though, got any rough sketches?
Re: Ebay Briar
Geez I haven't done one in years. Maybe I should. Here's one from a long time ago, and we are talking baby steps for the Sasquatch here.
They're fun, and a good way to use a rather rare piece of briar.
Do as you please, but in my logic, getting two pipes out of a single piece is not as special as getting one really rare shape out. You can get small freehands out of small blocks any day of the week, but a big sweeping horn is hard to find.
Re: Ebay Briar
I'm totally with Sas on this- you've got a ton of briar to play with- plan accordingly.
Re: Ebay Briar
Wow, you might have convinced me... That looks pretty sweet.
Re: Ebay Briar
yey!!Sasquatch wrote:Sasquatch votes for a big hunting horn from that block.
Re: Ebay Briar
Like this Sas?
Might leave a little of the plateau showing... dunno.
Re: Ebay Briar
Might I suggest that if you're going to leave some plateau on the bottom make sure you have a plan on how to make the transition between the plateau and the smooth surface look good. Do some looking at pipes that have used the same shape to see how they did it.
Re: Ebay Briar
I'm no pro, but I wouldn't leave plat on the bottom and I'd back it away from the plat just a bit. I've had plenty of times where the plat is deeper than I thought it was and ended up with some funny angles on pipes chasing pits.
Oh, and I'd cut the top of the bowl so that it lines up with that cross grain... I think it looks better that way.
Hello, I'm #1312.
That's a really big number.
Re: Ebay Briar
That's what I would cut from a block like that, yeah.
Have you got the drilling worked out? It's not super hard, but you might find that grinding a spade with a sharper, more conical end than usual (depending on your usual) might be helpful.
Re: Ebay Briar
Hi Gershom,
I am just a hobbyist so take this fwiw, I made something yesterday vaguely in this genre. You can take a look here: http://billboylepipes.weebly.com/horn.html and perhaps it will give you some thoughts.
- mightysmurf8201
Re: Ebay Briar
I like the horn idea. It also has given me the answer to a small, odd shaped half moon briar that's been sitting on the shelf in my office for months now, while I bang my head against a brick wall trying to decide what it should be . Thanks for the inspiration!
Re: Ebay Briar
Billiard, thanks for the inspiration! The pipe looks good, but I do not think I am going to try the rustication. I do however plan on using the U shape with the flat bottom being the plateau. What did you use to get that black color on it? Thanks!
Now if I can just get the time to actually do it...
