I know the pics are not the best from my iPhone. But I felt I put in a good effort this year. Started out clunky and leaning. But with filing and sandpaper it improved a lot. The contrasting stain came out good. I am not really a maker yet. But I have some skills I can improve on. Thanks to so many makers for all their encouragement. Carlos
My CPCC 2012 Seminar Pipe
Re: My CPCC 2012 Seminar Pipe
Carlos !
Good to see you here man. I had a blast hanging out with you and Allen and Phillip in the class and the smoking tent.
Your pipe turned out well man.
Are you taking the class again next year ?
Ryan Alden
http://www.aldenpipes.com
I may do so. It will be some time before I need to think about that. It's a great opportunity. I think I absorbed better this year things that I was told.
I think that pipe turned out pretty good, especially the stem/shank transition.
Good job.
Good job.
Thanks. I had intended to give this a slight bend. I am not a fan of straight pipes. But I was encouraged to not bend the stem. That it would look so much better. Well, as you can see, it's not really straight. Nor was it bent. File work and sandpaper gave it that nice, slight slant to the stem, which the more I worked, the better it looked to me.
I still have some Erinmore Flake if you want to see how the pipe smokes. Send me your address and I'll mail a couple bowls your way
Ryan Alden
I am quite sure that there must be a law against smoking Erinmore in central IL. Best to keep it with you in Texas. But thanks for the offer.Edward wrote:I still have some Erinmore Flake if you want to see how the pipe smokes. Send me your address and I'll mail a couple bowls your way
Good looking pipe. My only criticism would be the downward slanting stem. This pipe is drilled to be straight. If you want to bend the stem on a straight pipe you should exaggerate the cant of the bowl like the Zulu to restore balance, IMO.
