few more tNd's..
Re: few more tNd's..
I really like the lemon wood pipe for some reason. Was there bleaching involved?
Michael Labo
no bleach... the light is a bit to much... in reality the wood is a little bit more yellow than on those pic's and will turn more brown-yellow as it gets older ... but those are not major changes.. just a little bit....
Cmon man! Color grade your f'in pipes!!!!
Just kidding You do some great work man, still lovin' the wafer thin highlights you got rollin'.
Are you turning the highlight pieces on the lathe and thinning them there? Or are you perchance using a featherboard rig on a tablesaw?
Love the first one! Very pretty.
Beautiful work Daniel ! You really nailed #1 and #3
Ryan Alden
http://www.aldenpipes.com
Agreed. Nailed.Edward wrote:Beautiful work Daniel ! You really nailed #1 and #3
Chris
That Blowfish is incredible!! Very nice work on all of them, Daniel!
"Lemon tree very pretty . . ." (follow the bouncing ball)
Beautiful work. Kudos!
The Smoking Yeti wrote:Cmon man! Color grade your f'in pipes!!!!
thes rings that are thin are just a plain veneer ... wooden sheets that are 1mm thick.. i use them as separators here - to separate layers and to emphasize color of each layer.... and it works great.. but you need to stabilize them using 10mm or 12mm piece of wooden tenon through them... otherwise they will crack...
thanks to all for nice comments...
regards
daniel
regards
daniel
