Hey all. I anxiously await your critique. This is the first dremel-tool rustication job that I have done. I was told the recipient wanted something akin to Jake Hackert's Pokers... All I can say is that I tried. I do have one question; When you finish with Poly, you only put it on the stummel, right? Then finish the stem with Carnuba? Thanks again guys for helping me become better.
Algerian Briar, Vulcanite Stem
USMC Black, British Tan
Stummel Finish: Poly
Stem Finish: White, then Trip, then Carnuba
New Pipe
Re: New Pipe
In general, a very nice pipe. The overal composition is something I like.
However, did you polish/sand with the stem removed? The edges on the shank/stem transaction have pretty rounded corners. Furthermore I believe the stem is actually wider than the shank about .5" past the beginning of the stem? it kind of bulges out to the sides there....
I'm not sure how I feel about the rustication on the sides of the stummel, but I like the way it looks on the rim.
Re: New Pipe
Polyurethane is a no-no on pipes. It bubbles and peels if the bowl gets too hot. A thin layer of shellac is a better option.
Re: New Pipe
With "Poly" do you mean polish?
Polish the whole pipe (stummel and stem) with tripoli, and then the same with carnauba. I know some guys also use white diamond between the 2.
