Stem bending methods
lancefisher51
Re: Stem bending methods
Post by lancefisher51 »
Running under the cold water right away won't crack the volcanite?
Lance
Using Tapatalk
E.L.Cooley
Post by E.L.Cooley »
I've used hot water, with a cleaner. The cleaner makes a nice handle. But, I'm over scrubbing oxidation so I'll be looking for a gas lamp. Anyone willing to throw up a pic of one they like? Always right to cold water to set.
Sent from my banana phone.
Here's a good way to heat a stem:
Just keep the stem in motion over the flame so the heat doesn't concentrate too much in one spot. Heat until pliable. Bend.
andrew
Post by andrew »
Sasquatch wrote:Rad might be right, but there's no need to say it publically. :lol:
:D
andrew
andrew
Post by andrew »
I never use a pipe cleaner. I blow through the stem to set the bend.
andrew
andrew wrote:I never use a pipe cleaner. I blow through the stem to set the bend.
andrew
Winner winner chicken dinner.
mcgregorpipes
Post by mcgregorpipes »
lancefisher51 wrote:Running under the cold water right away won't crack the volcanite?
Lance
I usually stick them in the snow
E.L.Cooley
Oh got pounded with the white stuff yesterday. Will spring ever come?
Well I guess if you're in Manitoba, I'll quit crying about 6-8" (15-22cm)
wisemanpipes
Post by wisemanpipes »
andrew
I use a zippo or a alcohol lamp mainly because I hate dragging out the heat gun.
low and slow with no pipe cleaner. I dip my hands in ice water while im adjusting the bend but Andrew has it right, blow through to set it completely.
mightysmurf8201
Post by mightysmurf8201 »
I did this on a stem last month. Worked great :thumbsup:
#shellaclivesmatter
Emmanuel Atilano
E.L.Cooley
Well bent my first couple of stems with a candle instead of hot water. Why would anyone use hot water. Thanks to all of you I will not be doing that again. Candles much better.
I use a heat gun and set the bend with a spray bottle which I use for wet sanding. Definitely keep it moving. Occasionally, I will step outside and use the snow if my spray bottle was left in the shop and becomes ice.
pipedreamer
Post by pipedreamer »
On all real stems I use the standard ways, mostly heat gun on high.BUT! on acrylic I place the stem in a pyrex dish and cover with non-iodized salt.Then I bake at 350 for 12 to 15 min.Gives a more uniform bend,and use a pipe cleaner.You can shape the stem any way you want.You have to be gentle, this works real well. :thumbsup:
oklahoma red
Post by oklahoma red »
pipedreamer wrote:On all real stems I use the standard ways, mostly heat gun on high.BUT! on acrylic I place the stem in a pyrex dish and cover with non-iodized salt.Then I bake at 350 for 12 to 15 min.Gives a more uniform bend,and use a pipe cleaner.You can shape the stem any way you want.You have to be gentle, this works real well. :thumbsup:
That's the way optometrists bend the ear pieces on glasses. Hot sand or hot salt.
Chas.
Ratimus
Post by Ratimus »
I've been using steam from a tea kettle. Steam is much hotter than boiling water, but it still doesn't scorch or leave junk on the ebonite.
Ryan Richardson
R2 Pipes/Ryan's Luxury Goods
Ratimus
Post by Ratimus »
Come to think of it, is there any reason I shouldn't be doing this? Steam changing the dimensions of the mortise or something?
Ryan Richardson
I take mine to bed with me at night, they go in between my hot water bottle and teddy, when I wake up in the morning they are at the perfect temperature for bending.
Teddy supervises.
E.L.Cooley
caskwith wrote:I take mine to bed with me at night, they go in between my hot water bottle and teddy, when I wake up in the morning they are at the perfect temperature for bending.
Teddy supervises.
Now this is the method I will adopt from here on. Thank you for being will to expose a little of your proprietary process. I can't express enough my gratitude. ;)
oklahoma red
Teddy supervises.
TMI!!!!
Chas.
socrates
Post by socrates »
I taught my wife to bend with boiling water taken off the heat. Think I'll buy her a heat gun. Before anyone laughs I ask her to help as a way of getting involved. This makes it easier when I ask for tools and supplies. I can't drive or barely travel so it's great having her involved. OK now laugh if you want. LOL!
