Here is my latest. Just thought I would share.
I had a lot of dye bleed through (sorry Wayne).
Two Tone Rusticated Dublin
Re: Two Tone Rusticated Dublin
Nice. Has a bit of a "Savinelli Roma" look to it. I would suggest opening up the slot a bit, but that's merely based on what I've seen (and enjoyed) of some of the "big name" fellows out there.
I like it. The shape and the rustication are pretty good ! I'm ok with JMG about the slot...
Best regards,
Best regards,
Patrick Rijks
Nice work, Todd. Well done.
I can't believe I'm about to say this, but because the stain bled through into the chamber you might consider adding a bowl coating.
Yea, I was thinking the same thing.
Dude. I can't believe you put that in print (i was thinking the exact same thing).UberHuberMan wrote:I can't believe I'm about to say this, but because the stain bled through into the chamber you might consider adding a bowl coating.
Andrew
www.andrewstaplespipes.com
Dark times we're living in, Andrew. Dark times, indeed.andrew wrote:Dude. I can't believe you put that in print
Blame Todd Johnson for this crap!
