So it's something and not nothing. Making good progress here, guys.bregolad wrote:If it's not silica content, it's something.
Briar and heat transmission
Re: Briar and heat transmission
George the answer is one was oil cured
http://www.clarkpipes.com
has anyone tried one of those infrared thermometers with the laser pointer and measure the temperature of the bowl? could even measure the inside : outside temperature to see heat transmission which would add some control for chamber temperature.
I remember the first time I saw one of those. An HVAC tech was using it to balance the duct outputs in a building. Slick widget, for sure. Wanted one ever since.mcgregorpipes wrote:has anyone tried one of those infrared thermometers with the laser pointer and measure the temperature of the bowl? could even measure the inside : outside temperature to see heat transmission which would add some control for chamber temperature.
[pause]
I just checked Amazon, and they are now available for around twenty bucks.
http://www.amazon.com/s/ref=nb_sb_ss_c_ ... Caps%2C239
This will be fun.
Hey George, if you buy this one: http://www.amazon.com/Temperature-Infra ... rature+gun; you can scroll down and get a great deal on a Ghost Meter and a book about ghost hunting!! All three for one low price!
AND THAT'S NOT ALL!! ORDER IN THE NEXT TWENTY MINUTES, AND GET A FREE SAMPLE OF GENUINE ECTOPLASM AND A SHAMWOW AT NO EXTRA CHARGE!! BUT YOU MUST HURRY! WE CAN'T DO DIS ALL DAY.
RadDavis wrote:Hey George, if you buy this one: http://www.amazon.com/Temperature-Infra ... rature+gun; you can scroll down and get a great deal on a Ghost Meter and a book about ghost hunting!! All three for one low price!
Am I too late?????? Is there still time????????
I saw your question the other day, made a mental note to answer after I'd checked, then spaced it. Sorry.andrew wrote:Do you happen to have a make/model on these pipes? I've wondered about this for a while. Could be a fun project to try and work on. Do you have any dimensions on the pipes?
The two small pipes both have 7/32" thick walls. The smooth was made in 1890, and remained unsmoked until two years ago. The blast is a '64 Dunhill that I bought as an estate.
The bigger pipe is an LB-sized Castello with walls around 3/8" (the pebble rustication makes measurement inexact). It was included both as a size reference and because it is considerably hotter in hand than either of the little ones.
So the question is, would that Castello heat up for me too? Would anyone get the same results because it's that piece of wood (too light, too heavy, too much (not enough?) silica?) or is the fact that you can pull twice as much air through a Castello as you can the old English pipes to blame?
