this is my first pipe. I'm still working with only files and sandpaper other than than a drill press. i'm fully open to any critique, its ok to make it sting a bit. I'v really found my passion in pipe making and i want to do it well.
and p.s. i know this isnt the place for advice but any bits of info you may have to help my stem/shank junction tighter would be greatly appreciated. i always seem to put a small cut in one side of the stem while shaping the face where the shank meets and it makes a gap. i spent 4 hours and 3 premold stems to get it to this point
my first pipe
my first pipe
- IMG_6978.jpg (58.19 KiB) Viewed 478 times
- IMG_8933.jpg (66.53 KiB) Viewed 478 times
- IMG_4238.jpg (71.94 KiB) Viewed 478 times
Re: my first pipe
more pictures
- IMG_7209.jpg (82.07 KiB) Viewed 477 times
- IMG_6905.jpg (70.12 KiB) Viewed 477 times
Re: my first pipe
For your first pipe I say you done pretty good. Did you make the stem or is this a pre-made stem?
Re: my first pipe
its a pre mold but i thinned it to a much milder oval and thinned the taper of it a good bit and reworked the button. found out even with pre-made its still alot of work to get it where you want it
Re: my first pipe
I can only hope my first one looks as nice!
Re: my first pipe
To improve the junction between the stem and shank, use a flat file and file from shank to stem diagonally using a light touch. File around the diameter of the stem. For round shanks, give the stem a 1/4 turn after each time around the shank to keep it symmetrical. After roughing with a file, do the same with each grit of sandpaper. Never file, sand, or buff that area without the stem attached.
