Importance of Shellac ??
n80
Re: Importance of Shellac ??
Post by n80 »
Sorry to dig up this old thread but General Wood Turner's Finish was mentioned early in this thread. I looked it up and found this in the instructions:
"Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption."
Does this apply to applications like pipes?
Only if you use it like a sanding sealer, which you shouldn't.
On pipes, shellac (when used) is applied after you stain the pipe, and with an understanding that you will be changing that color slightly due to dilution of the stain, removal during the shellacing process, etc.
The WTF is a urethane, and where a sanding sealer proper you could stain over (on a weird wood like pine) the WTF would probably prevent most absorbtion because it is effectively making a barrier in/on the wood. WTF is good for certain stuff - black blasts for example as a final coat, but it's weird and not ideal on most smooths is what I found.
