Thanks,
Mark
??? If it were even it would look really dumb......and forced. This is very subtle and tastefully done.sandahlpipe wrote:The rim transition between smooth and blast is uneven. While it doesn't look bad per se, it's maybe a bit too much smooth.
The smooth part on the top looks funny in part because it comes down as far as it does. If you're going to leave the top part smooth, it should have the same stain color as the rest of the pipe for one. It looks like the smooth part is lighter than the rest of the pipe. I think the style of a partial blast where it transitions into smooth areas is a matter of taste.scotties22 wrote:??? If it were even it would look really dumb......and forced. This is very subtle and tastefully done.sandahlpipe wrote:The rim transition between smooth and blast is uneven. While it doesn't look bad per se, it's maybe a bit too much smooth.
It's a great pipe Mark
C'mon, you are the theater major around here. Say it with conviction, in the active voice, in a resonant baritone.d.huber wrote:This guy is hopeless.
I see a bunch of things that I could've done better to make that pipe work. I think a larger smooth bevel would've looked better or blending the sandblast back into smooth or something. As it is, I'm not sure the combined finishes work as well as I would've liked. Toku does it best.scotties22 wrote:If you subscribe to your theory that you shouldn't do something like Mark did on this pipe is David's blast on top smooth on bottom Tomato wrong as well?
d.huber wrote:C'mon, George. If you're gonna meme it up, meme it up right.
(My journalistic Spidey Sense is tingling...)The Smoking Yeti wrote: Not all though, cus' Ernie can only sparkle so much before he poops.
