How to stamp your name/logo
Hello everyone, I've been reading and searching about how to stamp your pipes. Today when stamping my latest pipe in the way I've been doing it. The bowl cracked! I use a stamp that must be hit with a hammer. I guess it had to happen sooner or later because I insert a wooden dowel in the chamber to keep it from moving when I hit the bottom with the stamp and hammer. My question is what is the best way to get better results. Thanks in advance!
Re: How to stamp your name/logo
Don't do that ! Just hold the pipe firmly in one hand, and press the stamp into the wood as hard as you can and use a small rocking motion to roll the stamp into the wood.
Ryan Alden
http://www.aldenpipes.com
Thank you, I'll try that on my next pipe.Alden wrote:Don't do that ! Just hold the pipe firmly in one hand, and press the stamp into the wood as hard as you can and use a small rocking motion to roll the stamp into the wood.
When in the process is the most appropriate and effective time to stamp?
I assume sometime after sanding and before final buffing. I recently received my stamp, and I am about to complete a couple of pipes. I would like to proceed with knowledge, not the trial and error method.
Thank you.
Rob
Thank you.
Rob
I always stamp right before applying the stain and buffing so the surface is not too slippery. That's just me, I don't know if everyone does.RobEsArt wrote:When in the process is the most appropriate and effective time to stamp?
Thank you.
Rob
Stamping is essentially the very last thing you do. If you stain or buff after you stamp, you'll inevitably get stain or compound inside the stamp. Ryan's (Alden's) suggestion above is the way most people do it, but it will take some practice. I would recommend you take a new block, sand one side smooth and practice stamping it until you get a consistent impression.RobEsArt wrote:When in the process is the most appropriate and effective time to stamp?
Stamp is the last thing except maybe bowl coating. DON'T use a hammer
If you have a choice of using that hammer again, resist. There are lots of was to stamp a pipe. A hammer striking a stamp is not one of them. Stamp companies sometimes say "strike end of stamp with mallet", which is fine for big flat surfaces... not pipes.
Andrew
www.andrewstaplespipes.com
If you are having trouble getting a good impression on pipes with your stamp try warming the stamp, not too hot, just warm enough that you need to wear a glove works well.
Gloves? That's for sissy's.caskwith wrote:If you are having trouble getting a good impression on pipes with your stamp try warming the stamp, not too hot, just warm enough that you need to wear a glove works well.
- sparkyspipes
Yepcaskwith wrote:Stamp is the last thing except maybe bowl coating. DON'T use a hammer
sparky (sparkyspipes)
The Pipe Carvers Guild
thepipecarversguild.com
Skype: Sparkyspipes
facebook: http://www.facebook.com/sparkys.home.3
Web Site: http://sparkyspipes.com/
YouTube: http://www.youtube.com/user/SparkysPipes
instagram: sparkyspipes
Skype: Sparkyspipes
Says the guy with a permanent burn between his fingers.PremalChheda wrote:Gloves? That's for sissy's.caskwith wrote:If you are having trouble getting a good impression on pipes with your stamp try warming the stamp, not too hot, just warm enough that you need to wear a glove works well.
Right before coating. Warm stamp and rock.Gloves mess with the feel. You could add a handle if you can't handle the heat!
Thanks for the assistance.
Rob
Rob
I use hot air gun on max mode to warm my stamp. About one minute.
Warm stamp works without force. But it can injure pipe if warmed too much, so i use the piece of polished briar to test before marking pipe.
Pipe is completely done, stamping is the last procedure. But carnauba wax goes later.
Thanks for all your the advice which seems to be the same "don't strike"!. Here is the result after some practice.
yep, thank you!Nate wrote:Looks good man, and no cracks!!!
- Thomas Tkach
I've seen the presses used by factories for stamping in some videos, and since I already own one of these, I wonder if it could be easily rigged to apply a stamp and allow for the rocking motion.
http://www.midwestsupplies.com/colonna- ... orker.html
It caps and corks well enough!
