Natural Prince
Re: Natural Prince
Not a bad one for the first try. To me, you just need to tighten up all your lines. Make sure there is no waviness on any. The bowl should be a bit tighter as well, tuck the heel a bit more and also the back (front for Wayne/Tyler). The stem bend seems off to me as well. Princes have graceful bends, but this one doesn't seem to have as much grace as it should. Others far better than me will have better input on these points, so listen to them. Not too shabby for your first run!
Re: Natural Prince
Not too shabby. The biggest issue to me is the pipe lacks definition. None of the lines are crisp and true the way you want them. The top of the bowl, transition to the shank, the lines of the shank. It is all a bit formless and not well enough defined.
Ryan Alden
http://www.aldenpipes.com
Re: Natural Prince
Some good stuff from Nate and Ryan.
I would really concentrate on the bowl on the next one. Work on making the lines sharp and giving the entire pipe a bit more focus. If I held a perfectly executed prince up and then squinted your pipe is what I would get. You got the bones down pretty well.....now it's time to put some fine ass eye candy on top.
You already know how to make the shank and stem better on the next one and doing so from the beginning will be much easier than trying to fix one midway through.
- mightysmurf8201
Re: Natural Prince
The thing that stands out the most for me is the rim. It needs some definition. I've seen some of your work, and it's pretty good, but that rounded over rim does not reflect the reputation that you have worked hard to establish so far. It makes it look like a pipe turd, and I know you don't make pipe turds. Most princes have a flat rim. Never seen one rounded over like that. Not bad overall though. I look forward to seeing more of your work.
Re: Natural Prince
thank you for the feedback, all things I will work on for sure. Not to sure why I ended up rounding the rim over come to think of it, next one I will correct that issue as well as work on the others brought up and hopefully the next prince I will have at least a bit of that fine ass eye candy to go along with the bones.
Re: Natural Prince
Keep that ass candy off your pipes...363 wrote:the next prince I will have at least a bit of that fine ass eye candy to go along with the bones.
Re: Natural Prince
sandahlpipe wrote:Keep that ass candy off your pipes...
This^^^ from the dude who has something about liking kankles in his tag line
Re: Natural Prince
Sorry, but after further reflection I realized that the ass candy comment belongs in the vegan shellac alternative thread.
Re: Natural Prince
Re: Natural Prince
Is ass candy vegan?
Ryan Richardson
R2 Pipes/Ryan's Luxury Goods
Re: Natural Prince
Brendon,
What Nate said, and to further reflect on how to achieve the more smooth lines is to use a flat file or maybe sandpaper over a flat surface to shape from where the bowl meets the shank all the way to the button. You need at least 1" of straight cutting surface that is flat. This will teach you how to use your hands to achieve a very crisp flowing line. You can then practice using a disk or belt once you have got a handle on using a hand tool to do it.
- Joe Hinkle Pipes
Re: Natural Prince
All good suggestions. What I see on the rim is a rounding over from the side of the bowl to the rim. Thats the issue. Rounding the rim usually makes a nice finishing touch, so I would continue that. You just have to make a distinct break from the bowl to the rim.
Re: Natural Prince
Great notes from everyone.
The stem appears to bulge slightly after the stem/shank junction in the top and bottom photos.
Re: Natural Prince
I don't see the rim as a problem; it's a look. It's not a great look, but I don't think it puts you in the "turd" category as mentioned above. As a few others mentioned, your lines need to be dead straight. Weak lines detract from the composition, and strong, true lines lend confidence to the piece.
Re: Natural Prince
Yeah, I noticed in the photos that the stem wasn't as smooth as I thought it was. all good feedback and I plan on putting it to use in the future for sure. Thanks all
Re: Natural Prince
Just as an aside, that's an extremely difficult pipe to make well. It's much easier to lose control of a curve here or there, have something be lumpy, or too flat... like, making a nice, bangle-free Prince is a really hard thing to do. That's not a great pipe but it's not a turd by any means. That pipe has 34/558 things done just right, and the next one you can get 40/558 things, that's how this works for most of us.
Re: Natural Prince
I bow to the Sas! Well said, Todd! That's exactly how it goes, just way more eloquently put than I would ever have been able to!
