No. 3
Revelation
No. 3
Post by Revelation »
Here's number three, A canted nose warmer I made for a friend. I am pretty happy with it overall, I know it has flaws though.
I used delrin for the first time and also two different stains this time. I still struggle with the junction at the bit and stem a bit though.
"When He had taken the book, the four living creatures and the twenty-four elders fell down before the Lamb, each one holding a harp and golden bowls full of incense, which are the prayers of the saints"
Re: No. 3
Where do you see the flaws?
Revelation
Re: No. 3
The pics aren't great but where the bit meets the rest of the stem. On the sides of it where the file would nibble some when rounding the edge. I figured it was better to leave it as is rather than doing irreversible damage to an otherwise good bit. Also, two pis showed up on the shank. Not very big yet I chose to leave them as is.
Re: No. 3
The biggest two things I see are he shaping on the bottom of the bowl, you've got too much material both on the front and on the back of the bowl. Then the button work needs some help. Avail yourself of the techniques demonstrated in LatakiaLover's video on stems.
