I wrapped this one up and put the finish on it after getting to a point where i feared diminishing returns. I took a little too much off the chin for sure. This was a great learning experience in setting the pipe down in between working on others. Each day i took another look and found things that needed adjustment.
Someday I want to master a billiard and try to put one now in every group of blocks. I Appreciate any and all feedback.
Thanks,
Jeff
Billiard - Appreciate any feedback
my mouth is the marketing department for the circus in my head
Re: Billiard - Appreciate any feedback
So here are my thoughts:
- chin too big a radius as you mentioned
- maybe too sharp a taper in the shank when viewed from above/below
- you could cut that line on the back of the bowl just slightly more vertical where it meets the shank
- I can't tell if the angle is drilled at 90 degrees and the rim is perpendicular, or if the angle is drilled at ~93 and the rim isn't quite perpendicular. In either case it looks like it's too high in the front
- slightly asymmetric button shape, which is something I do too (it's a little pointier on the right side)
- I think it could actually be a little puffier in the cheeks but that might be from you blending the chin... also consider the source on that one (AKA Mr. Chubby Cheeks )
All in all it's a pretty sharp looking pipe I think.
Thanks for taking time to give feedback those are all very good points
An attractive pipe. I don’t find anything other than Rick’s (and your) spot on critique.
Nice job.
Nice job.
Are you taking off your first stain on the buffing wheel?
It looks like your are over-agressively removing color, particularly around the rim of the bowl. There are a few spots on the shank as well.
600 grit paper allows you to remove stain more evenly.... though it is more tedious.
