https://photos.app.goo.gl/RkJp44aotP5iE1Nt5
Just got a metal lathe. This was the first spin. I know the shape is still irregular, but feel there has been improvement in my work.
Appreciate feed back.
Thanx
Making progress
Re: Making progress
Next step is to turn the shank completely round from button to bowl/shank junction. If you’re in doubt, check with a straight edge. The bowl shank junction itself should be no more than 1/4” of a radius, and probably a little less, depending on the overall size.
Re: Making progress
Thank you. I had trouble with that part. When I first took it off the lathe it looked like a perfect pipe trapped in a mini block of wood. I had trouble removing the rest of it and getting the bowl shank transition to look right. It was the first one on the lathe and think I just need more practice.
Re: Making progress
The trick is thinking through how your tool is designed to work and which part of the tool removes material where. There’s plenty of room left on this to go back and shape the shank round. Focus on one line at a time. Make the top flat and parallel to the bottom line. Then flip the stem and make sure your stem fits upside down. Then do the same on the sides. Then round the corners, rotating the stem often to ensure you’re staying centered.
Also, watch Latakia Lover’s videos. They’ll be instructive in general, but specifically, he has a segment where he talks about how to get rid of lumps. I believe it’s in his diamond shank stem replacement video.
Bobm5586 wrote:Thank you. I had trouble with that part. When I first took it off the lathe it looked like a perfect pipe trapped in a mini block of wood. I had trouble removing the rest of it and getting the bowl shank transition to look right. It was the first one on the lathe and think I just need more practice.
Re: Making progress
Using Jeremiah’s method, you can get a nice round shank without a lathe. Don’t take off much material before you rotate the stem. I rotate 90 degrees and 180 degrees for a round shank, 180 degrees for diamonds and ovals.
