First pipe in a while
ReverendThom
Post by ReverendThom »
It had been quite a while since I attempted to make something resembling a pipe (over a year?).
I know there's lots to improve, so open to everything and anything you can offer for advice on improving. What would you focus on most on the next one?
Sent from my SM-G965W using Tapatalk
Re: First pipe in a while
Ok...you get critique from PNG. Rustication: I would suggest to keep going with it. As it is, it looks like you stopped halfway through. Your second pic shows the that you lost the curve of the shape (its cheeks). Still to this day, I have trouble taking too much off that part. It looks like your bowl is almost tilted back toward the stem by a degree or two. This probably is not the case, but one thing this forum has taught me is that if you drill the chamber at 90 degrees to the draft hole, it will almost always look off. You need a couple degree tilt forward to get by this optical illusion. Third pic down, your shank appears to bulge in the middle a little bit. To quote Wayne, "Sand the chamber!"
All in all, a perfectly smokable looking pipe. Have fun making another one.
ReverendThom
Thanks buddy! I was surprised how tricky rustication is. I need to sharpen the nails a bit better I think.
Some helpful advice here!
ReverendThom
Or maybe it's not really tricky but I've just discovered a way to make it so? Haha
