Noob question on staining part II
After i've used the dye ( usually fiebing's), the colours on the pipe are always opaque. What can i do to improve the colours and to make them appear less opaque? Do i need to buff the pipe? How?
Re: Noob question on staining part II
The stain must be buffed eventually. I use a thin shellac coat which can be rubbed to even out the stain- I use a make up pad.
I sometimes sand after this dries to achieve greater contrast, then you can use either an oil or more shellac before buffing.
I generally buff with Tripoli on a wheel (Beall system). For tight areas, you can buff with a strip by hand- fix the pipe in place with a jam chuck or senior reamer, or fix one end of your cloth strip and move the pipe.
If you buff before shellac or oil, the wax/grease matrix of the buffing compound may interfere with finishes.
as always, you're very helpful, thank you DocAitch. Right now i'm making an octagonal billiard, following youre advice on how to make one. Well'se how it goes. Thank you!
