another quick rustication question
I am going to build a tool like tyler showed.
When i use it how hard do you press and do you have to twist it to remove the briar?
How sharp does the nails have to be?
sorry for all the silly questions.
Not trying to withhold information here or anything but...
That's the beauty of this particular tool. Do whatever you want. Create your own look. Your messing up the briar regardless... For the basics: yes, press and twist. Other than that it's up to you. Carve different profiles into the nails, use different tools (nail tool and a philips head screw driver with a line cutting in 1/4's), mix it up! That creates the best result. I think, and I know that lots of people agree, the best rustication is a sporatic one. One that you can tell how it was done, can see patterns. One piece of advice, to get real nice rustications like those who have used this tool well, expect to go over the same spots several times.
As suggested by others with similiar threads, also use a dark coating of stain so you can see where you have worked it. When all the stain is removed you should have a nice even thickness all the way around rather than having some spots thinner.bscofield wrote:One piece of advice, to get real nice rustications like those who have used this tool well, expect to go over the same spots several times.
Argue for your limitations and sure enough, they're yours. - Richard Bach, "Illusions"
Re: another quick rustication question
If your hands are numb after you're done, you've used enough pressure! 8O The tool will tell you how much pressure. If you're not popping chunks out of the briar, you probably need more pressure.When i use it how hard do you press and do you have to twist it to remove the briar?
The best way to learn is to take a scrap piece of briar and try all sorts of techniques. And its fun to experiment. Can also be painful though, make sure you wear protection.
David
CKR,ckr wrote:Kelvar,
I think they are better to guard against a slice - I would think several sharp nails would work themselves between the fibers?
You're right (typos aside) it's kevlar. I am clumsy and would benefit greatly from getting a pair. Anyone out there have them? Where did you get them?
Thanks,
--Michael
Your clumys, I cna't enve type rihgt.
http://www.woodcraft.com/family.aspx?FamilyID=1342
I'm sure there are many places.
Fumo in pace :pipe:
I use concrete nails with the head cut off in the compression fitting. Before putting each into the compression fitting I first sharpend each one on a grinder to a sharp point in the same way you would sharpen a pencil.
John
www.crosbypipes.com
www.crosbypipes.com
For this -
You can forget Homeless Depot - you need to go to a Plumber's Supply Store. A tee, threaded black iron, a coupler and, a compression fitting.
Make sure all the stuff is threaded right, work from the compression fitting and then back.
Print the pics and take em with you.
Fumo in pace :pipe:
Home Depot is where I bought the stuff for mine. (Well, OK, maybe it was Lowe's...I don't remember. It wasn't a plumbing supply house though.) It is not strange stuff.
1/2" threaded pipe fittings (I used galvanized):
-tee
-nipple (I like about 4" -- the photo is much longer)
-coupling
and a brass pipe-thread compression fitting.
All should be on the same aisle.
The masonry (concrete?) nails will be on the hardware aisle with the rest of the nails.
-tee
-coupling
