Acrylic is a little more tricky to bend than vulcanite, and bubbles in the acrylic can be caused by overheating it. They are a pain to get rid of because they can go quite deep--so next time try going slower and using less heat.
Yes, it looks like overheating to me too. Those acrylics with metallic flakes as part of the decoration tend to burn MUCH faster than straight acrylic. For that matter, I've found when using PME's "ice" acrylic (transparent with a white swirl) the white part will burn and blister before the transparent is hot enough to bend if I'm not extremely careful.
I just finished a very nice bent dublin and after I hit the stem with white trip I noticed that there are small "sand pits" in the stem. I use ABS rod for my stems and have yet to have this problem. My guess is I overheated the stem. (It was a pain to bend). Any suggestions for getting this out? I've been sanding on it without luck. The stem has such a nice insert that i cant bare to toss it.
I've been trying to. But I'm on a deadline and i'm not sure if sanding it would be in vain. here are some photos. Let me know what you think. I've never had this happen before.
I'm not all that familiar with ABS. However it certainly looks like the material got overheated. The real question is how deep the bubbles go. You might be effed here, and you might have to start over. You could use a 180-grit nail file to quickly cut into the surface and see how far the bubbles go.
Personally, knowing how ebonite reacts under similar circumstances, I'd just start over. Call it a lesson learned and keep it in mind for the future.
It looks like you can already see the airway in these pictures. And with that much surface area bubbled on and around a curve, odds are it's deep. Most likely better to just start over. At least you can mate the tenon ends of this one and the new stem together to speed up the shaping and sizing of the new one with less risk of sanding the shank.
