Filing affairs
tritrek
Filing affairs
Post by tritrek »
Hi all,
I§ve just finished this tamper out of maple wood:
I just have a question: what do you use to fine sand in very narrow parts? If you check my tamper, I'm talking about the part where the "scroll" meets the "neck"...
It's not only about making things perfect, it's more about rougher areas taking up more dye and so becoming darker than other areas..
Thanks!
T3pipes
Re: Filing affairs
Post by T3pipes »
ideas--3M sanding sponge
sandpaper made with a flexible paper, fold it over and use the edge
Dremel abrasive buffing wheels http://www.dremel.com/en-us/Attachments ... x?pid=511E that can be cut to shape to fit a small space.
tritrek
Re: Filing affairs
Post by tritrek »
Great ideas! I've tried the folded sandpaper but the problem is, normally only lower grits are textile backed, finer are paper backed and break quickly :(
kbadkar
Re: Filing affairs
Post by kbadkar »
There is also "sanding cord", which is what it sounds like, abrasive on a string. Also, sanding wands are super handy. I use the wands all the time. I'll see if I can find links.
abrasive cord -
http://www.micromark.com/ABRASIVE-CORD- ... ,6488.html
sanding wand -
http://www.micromark.com/MICRO-SANDING- ... ,7760.html
other options -
http://www.micromark.com/5-PIECE-FLEX-PAD-SET,7367.html
http://www.micromark.com/SANDING-TWIGS- ... ,9336.html
Micromark isn't necessarily the best supplier. Shop around.
