long belt sander
long belt sander
where can I get a long belt sander with no backing for light sanding stummles? Or does anyone have an idea how to build one? I need it to be 2" wide by warever tall thanx Bob Clark
http://www.clarkpipes.com
Re: long belt sander
Try Ken Lamb.
- christopherthaley
I picked one of these up not too long ago, and I've been pretty happy with it so far--especially considering that it is much cheaper than a lot of other options.
http://www.craftsman.com/shc/s/p_10155_ ... elt+sander
In the photo it has a backing plate, but it's easy to move it back out of the way or remove it completely.
Tom
Tom
"Only the brave return to the source"--Hölderlin
For stummels you will need to have one specially built with a frequency modulator or similar meens to contoll speed and it ain't cheap
Heres ours wich I built togheter with the village smitthy some months ago
I'll second this suggestion. If you want to do slack belt sanding of stummels that's probably the best ready-made tool you're going to find. Just be sure to get a DC motor (or 3-phase AC) and speed control to run the thing so that you can slow the belt *way* down, otherwise you're going to burn the shit out of your hands.Uncle Arthur wrote:Try here http://www.cootebeltgrinder.com/
Beyond that, if you have any welding skills at all, and the ability to lay stuff out and measure twice, you can build a grinder for very short money - especially if you use scrap steel to put it all together. Slightly more expensive, but still affordable, is some bolt-together designs - all of which can be adapted for slack-belt sanding.
Whatever you do, don't get one of these. It's utter crap:
http://www.grizzly.com/products/Belt-Sa ... -30-/H3140
You could possibly use a 1x42 sander with some patience, and perhaps some modification, but that belt still spins way fast. If you replace the belt or motor pulley you could slow it down quite a bit.
Another word of warning - some knife makers use these:
http://www.grizzly.com/products/Knife-B ... ffer/G1015
This spins way fast, and is not well suited to your purposes at all.
- SimeonTurner
*Sigh* I wish I had a village smithy in my town. Stupid suburban America...geigerpipes wrote:For stummels you will need to have one specially built with a frequency modulator or similar meens to contoll speed and it ain't cheap...
Turner Pipes Website:
http://www.turnerpipes.com
Of Briar and Ashes:
Of Briar and Ashes:
We have one here in Foley. He's under the spreading chestnut tree.
Some time ago (OK, maybe WAY back) there was a post on the system that Rainer Barbi uses. Anybody uses the same type thing or know of anybody that does? I got hold of a couple of nice long wide belts, have a motor with +- 450rpm and was wondering if it is worth the while to try and build/swear/modify something myself?
Go for it!
No kidding? Does he have "large and sinewy hands"?RadDavis wrote:We have one here in Foley. He's under the spreading chestnut tree.
- SimeonTurner
Of Briar and Ashes:
Of Briar and Ashes:
Anyone who underestimates the erudition of PMFers or Alabamans, be forewarned, if you would hit the mark, you must aim a little above it - the supreme excellence is simplicity.
Here is a similar belt sander that I copied from pictures posted in forum way back. The only true costs were the nuts and bolts, the wheels, the rod and the...not sure what they are called, but they hold the rod in place.
All the best,
Tano
Tano
Those are called pillow blocks. I think.Tano wrote: the...not sure what they are called, but they hold the rod in place.
Great stuff! Exactly what I was thinking of Tano! What rpm does the motor have and the HP?
The motor is rated at 1750 rpm but I beleive that if you put a large pulley in front it slows it down quite a bit.
I experience no issues with it especially finger burns.
All the best,
Tano
Tano
Sorry Charl! I forgot to mention that all my motors are 1/2 hp.
All the best,
Tano
Tano
I use cheaper version of this, sold by Harbor Frieght for $29, to do just about everything.Whatever you do, don't get one of these. It's utter crap:
The Grizzly 1015 so called knife sander is too fast to properly use for knife work. Especially if you spend the extra bucks for the larger contact wheel.
