blasting
andrew
blasting
Post by andrew »
Finally ordered my cabinet. Now I just need to dig up a bunch of sand in my backyard :D
SchmidtN
Re: blasting
Post by SchmidtN »
Hello, I'm #1312.
That's a really big number.
Re: blasting
andrew wrote:Finally ordered my cabinet. Now I just need to dig up a bunch of sand in my backyard :D
Suhweeet! Can't wait to start seeing those blasts roll out. :D
andrew
Re: blasting
Post by andrew »
Now I've got all the part/pieces coming too.
The Smoking Yeti
Re: blasting
Post by The Smoking Yeti »
What unit did you get?
http://yetipipe.tumblr.com/
Re: blasting
I know this was meant in jest, but I feel duty bound to tell folks that this is a bad idea. Using actual sand for sandblasting is exceedingly dangerous for your lungs, and can result in silicosis which is a horrible and painful way to die.
SimeonTurner
Re: blasting
Post by SimeonTurner »
Kurt, you shouldn't be blasting anything into your lungs. Sand, glass bead...it's really bad to wrap your lips around your blaster.
Turner Pipes Website:
http://www.turnerpipes.com
Of Briar and Ashes:
Re: blasting
That sounds like something I might see in a Final Destination movie...
DMI
Re: blasting
Post by DMI »
I was in A&E once when a guy came in who had tested his shot blaster on his gloved hand prior to de rusting a chassis, not a lot of glove, flesh or bone left in his palm.
David.
andrew
Re: blasting
Post by andrew »
The Smoking Yeti wrote:What unit did you get?
I just got the e100 cyclone. I couldn't justify anything larger with my brain, my ego on the other hand saw a trinco that was beautiful. I left the trinco alone for now.
And yes Kurt, the sand in my kid's sandbox is safe, it would be a shame to blast a pipe with sand desicrated by the local feline population. The dying part would suck too.
Just so everyone knows:
REAL SAND - BAD
BLASTING MEDIA BOUGHT FROM A REPUTABLE SUPPLIER - GOOD
:D
Cory
Re: blasting
Post by Cory »
REAL SAND - BAD
:D
Man....don't let those "reputable suppliers" trick you like that. It is just another lie corporate America is force feeding us! Fight the man, use play sand!
