To start off, you're doing fine work for where you are in the process. You've asked for honest feedback a couple of times, and that's wise. I just don't want you to think that you aren't doing well.
To be candid, the shank being off to the side is the least of your worries; you know what the problem was and you can (I assume) correct it next time. The bigger issues deal with proportion, and this is a much more difficult perception to cultivate. Here goes...The size of the bowl requires a larger shank - either longer or fatter or (probably) both. The stem is also too short for the height of the bowl. The bend in the stem is too abrupt. The bit needs to be thinned out significantly, and the button is too clunky (almost as bad as one of Sas's... yikes!).
In my opinion (and you'll undoubtedly hear how valuable that is below
) the stem and especially the button will be some of the last things to come together for you. That's partly just because how one shapes a button is very subjective. You'll sort of ease into a style that you like, and some people will like it while others won't. I'm saying this to encourage you to focus on stummel shaping before focusing too much on the stem. Stem work is tedious enough at first, so no need to burn yourself out on it.
Keep at it!
