flake or spray shellac for amateur maker
Trying to determine which method I should use. I'm leaning towards Zinsser due to the eas of use. I'm finishing my first pipe and don't plan to quit my day job.
I've gathered that flake shellac should be cut with denatured alcohol to about a 4 or 5-pound cut. The resultant mixture should be filtered. I assume a coffee filter would work here?
I've also read on here some use Zinsser spraycan shellac on a pipecleaner. I started looking and found the following comment from another thread "The Zinsser Seal-Coat is 2 Lb dewaxed. The Zinsser Shellac (both clear and amber) have wax. Not sure what cut they are though."
So, if I use Zinsser, which product should I use.
thanks everyone.
thanks everyone.
Re: flake or spray shellac for amateur maker
Neither, buy it pre mixed in a can. Spray is messy/imprecise (if you're me) and cutting shellac is more expensive than buying a good Zinser 100% wax free can. You'll get good results and save yourself $15-$20.
Andrew
www.andrewstaplespipes.com
OK, can it is. Is there a specific label I should be looking for? Will I need to cut the pre-mixed can?
You will probably need to cut just about anything you buy. Shellac thinner or methyl hydrate or ethyl alcohol (safest) work.
I buy Zinnser in the smallest can at Ace and thin it with denatured alcohol until I get a finish that gleams rather than shines.
The older shellac gets, the longer it takes to dry until finally it just stays sticky, so a smaller can is more desirable than the "large economy size" for pipes. Even the smallest cans will get too old before you run out, unless you're making a lot of pipes
Thanks Andrew, Sas, and Rad for the advice.
Two products are available: Any suggestions?
The Zinsser Seal-coat is 100% wax free so I'll assume this is what is preferred.
http://www.rustoleum.com/CBGProduct.asp?pid=246
The Zinsser Bullseye isn't 100% wax free and I assume should be avoided.
http://www.rustoleum.com/CBGProduct.asp?pid=245
Go with the first one. Wax free. You will probably need to cut it, but you can use it straight too, just depends on the look you're after. Full strength is very shiny, 1:1 cut with DNA will gleam like Rad says.
Andrew
And I use Bullseye.
I just checked my spray can of bullseye- it's 100% wax free.RadDavis wrote:And I use Bullseye.![]()
So I gather either product will work. I suppose I'll make my choice based on which comes in the smallest container I can find.
PS: While at the store looking at baby food jars to mix the shellac and alcohol in, and knowing I would eat said baby food to empty the jar, I chose the fruit medley instead of the turkey dinner. I've never had my jaw wired shut, but pureed turkey dinner didn't sound appetizing.
Ah, So both of them are Bullseye. Nevermind.GPipe wrote:Thanks Andrew, Sas, and Rad for the advice.
Good call with the fruit medley. The turkey dinner is pretty bad.GPipe wrote:So I gather either product will work. I suppose I'll make my choice based on which comes in the smallest container I can find.
Shellac comes in baby food flavors, now?scotties22 wrote:Good call with the fruit medley. The turkey dinner is pretty bad.GPipe wrote:So I gather either product will work. I suppose I'll make my choice based on which comes in the smallest container I can find.
Blueberry Buckle for me. Good on ice cream too.
Jeeze, give us some credit here. We're talking storage containers. You gotta get something you like to eat because no baby in their right mind will eat most of that crap.
And yes, Blueberry Buckle is the shit.
This thread is getting weird.
That turkey flavor was designed by someone that hates humans.GPipe wrote:So I gather either product will work. I suppose I'll make my choice based on which comes in the smallest container I can find.
Andrew
The Smoking Yeti wrote:This thread is getting weird.
This whole forum is getting weird.
Ryan Alden
http://www.aldenpipes.com
Our baby eats most of the combinationsscotties22 wrote:Jeeze, give us some credit here. We're talking storage containers. You gotta get something you like to eat because no baby in their right mind will eat most of that crap.
Is it the end of the world??
Seriously, I can vouch for baby food containers being real cool for keeping stuf!
