I have been messing with oil curing. Currently I have a pipe almost complete on the bench. The bowl is Osage Orange and the stem is Elm with a vulcanite Lovat bit. Both pieces of wood are oil cured.
The tenon on the wood stem is only a quarter of an inch where it is fitted to the bowl. There is very little meat left in the bowl to use a threaded rod to put them together for added strength. I am leaning toward using epoxy to join them.
Anyone have any experience in glue to do this with? This is my first time trying it on oil cured wood?
Other glues I have used on dry wood have been Titebond III, Gorilla Glue, and Super Glue gel.
http://home.woh.rr.com/aknots/images/Pi ... e-elm1.jpg
Glue to attach a wood stem to a bowl.
BobH Choice Basket Pipe Maker
Flatland Pipes
Flatland Pipes
- LexKY_Pipe
- LexKY_Pipe
Yes. Nickel silver discs 1/8" thick and 1" in diameter.LexKY_Pipe wrote:What a website! Is there anything they don't stock?
The epoxy I use is available from woodturnerscatalog.com - I like the T-88 structured epoxy:
http://www.woodturnerscatalog.com/cgi-b ... y=167-0888
It's a slow-cure epoxy, 6-8 hours to set, 24 to working strength. I like it because I mix up a bunch of epoxy and batch a bunch of stems and shank extensions without the epoxy going hard an unuseable on me.
I don't have a answer to your question but I just posted a question of my own about oil curing briar. Any information you can share with me on this subject would be appreciated. You can email me if you like, lib7273@msn.com.
Thanks bill
Thanks bill
