My first briar pipe!
Hello!
Armed with the 'pipemaking for the rank amateur' article and some enthusiasm, I purchased a briar kit and had some fun. I've been a painter for years and needed to switch gears and try something new. Slightly overwhelmed by all the knowledge I tried to absorb online, I had what Tyler calls "analysis paralysis" and had a hard time knowing how to start. So, letting go of expectations of grandeur with my first attempt, I just jumped in without a design or plan and went at it with a dremel. I figured as long as I had fun making whatever mistakes I was about to make, then I'd be moving in the right direction. I wanted to try the various kinds of bits and see how they performed, I wanted to see just how much trouble I'd be getting into my doing something figurative and detailed, and generally see how I felt about the whole process. I had a great time, here's what I did:
I now have a new block on my bench, waiting to figure out what it wants to be. Thanks to all of the contributors of this forum, I spent a number of my breaks perusing all the eye candy and being inspired with everyone's ingenuity and creativity.
~Paul
~Paul
- baweaverpipes
- The Awesomer
Re: My first briar pipe!
It's obvious you're an artist and I dig what you have done with your first piece of briar.
Very cool!
Very cool!
That's pretty cool! My only criticism would be that the tobacco chamber is strangely shaped. Very creative though.
Oh, and I'd put a slight bend in the stem.
Oh....and sand your tobacco chamber.
Thank you Wayne, I appreciate your constructive feedback! I did bend the stem slightly upwards, but it might be too subtle for the photo angle. I'd never bent this material before, so I erred on the side of caution as I did it over a candle and didn't know how quickly it would soften up. What grit of sandpaper would you use for the chamber?
Wow! Glad you let go of your expectations.letting go of expectations of grandeur with my first attempt
Very imaginative. Looking forward to pipe #2.
-Pat
Now that you mention it, is see the slight bend but I meant the other direction.nightserpent wrote:Thank you Wayne, I appreciate your constructive feedback! I did bend the stem slightly upwards, but it might be too subtle for the photo angle. I'd never bent this material before, so I erred on the side of caution as I did it over a candle and didn't know how quickly it would soften up. What grit of sandpaper would you use for the chamber?
180 or 220 grit is what I use. It gives it a more finished, professional look. Of course, I'm obligated to mention it because I jokingly ranted about it a good while back so take it with a grain of salt.
That's pretty cool! IAWW
Nice work. I think the assymetry should meet even David's standards.
One of the Southern states has a Wild Boar-themed football team (Texas, maybe?). Betcha more than a few fans would love to have that on their desk at work.
well, I am on pipe number 50 something at least, and there's no way i could hope to make that. i should probably quit haha. but, seriously that's an amazing first briar pipe.
That's very cool.
You obviously have a great imagination and you know where to look for the necessary info- that's all it takes to start making very interesting pipes! (plus some briar )
Just one piece of advice- don't be afraid to apply your creative ideas to the mouthpiece too. If you use a piece of ebonite rod (already drilled and fitted with a tenon if you don't have the equipment to do it yourself) instead of a shaped blank you will have enough material to carve it and make it fit the pipe aesthetically, not only functionally.
Have fun!
Have fun!
I think you're right.sandahlpipe wrote:Nice work. I think the assymetry should meet even David's standards.
Nightserpent, ditch the preform stems. You don't need them. Start buying ebonite rod. It'll set you free.
Thanks for everyone's feedback, it is nice after all that effort to be able to share it with people.
Here's a more even side-shot to show the subtle upward bend of the stem:
Wayne- are you suggesting a downward bend for aesthetic or functional purposes? If the former, I'm guessing it would be to make an S-curve? I thought it might be beneficial to be able to see more of the bowl when it is being lit. Where the inside of the bowl was stained (it sounds like doing this is in debate) it is quite smooth to the touch, though the farther down the hole the less equipped I was to maintain that quality and used ceramic dremel bits.
Pat- Rather than get too bogged down with designs and details it seemed best to just focus on working with the various tools and materials... and getting as many mistakes out of the way as soon as I can.
LatakiaLover- I showed my brother the pipe when it was rougher, and he suggested the same exact thing! Sounds like a strong fanbase for the team. What some see as tusks (and I can see why because of the pig-like snout) is actually intended to be dual forked tongues. I do a lot of fantasy/sci-fi illustration for work, and one of my specialties is unusual monsters.
Josh B.- 50? WOW! It's worth mentioning that I have been painting/drawing/making stuff my entire life, I was fairly solitary as a kid and so that's how I would entertain myself... decades later and I have never stopped. So though this is my first real attempt at making a briar pipe, I find a lot of the skills translate and probably give me a bit of a leg up. It's probably like learning a new language after already learning several others.
W.Pastuch & d.huber - I certainly aspire to get more creative with the stems, and that sounds like a good step in that direction... and who doesn't want to be set free? I will, of course, look about for myself, but if there are any good examples of unusual or creatively carved ebonite stems I would love to see them so I can get some sense of it's potential. Is there any way to reduce the pungent odor while working with ebonite/vulcanite? Even sanding it lightly by hand is pretty foul.
Check this article out to see some creative shaping with ebonite: http://tobaccodays.com/articles/pushing ... ou-part-2/
With ebonite rod and plate, your options become fairly limitless. Talk to Steve Norse, aka Vermont Freehand, for easy purchasing. http://www.vermontfreehand.com
Or... http://pipemakersforum.com/forum/viewtopic.php?t=4136
Like the smell of your own farts, you'll learn to love it.nightserpent wrote: Is there any way to reduce the pungent odor while working with ebonite/vulcanite? Even sanding it lightly by hand is pretty foul.
The S curve is both functional and aesthetic. It will allow you to clench the pipe more easily (if you choose to do so). It's your pipe, but to "pipe guys" it just looks wrong. Not a big deal though since you weren't exactly following the rules when you made that.nightserpent wrote: Wayne- are you suggesting a downward bend for aesthetic or functional purposes? If the former, I'm guessing it would be to make an S-curve? I thought it might be beneficial to be able to see more of the bowl when it is being lit.
Usually you want to remove the stain from the inside of the bowl; it just looks more professional that way. Wayne is especially... uh, sensitive to this. I would say he's right on both points though.
I'm interested in seeing your next piece.
e Markle wrote:The S curve is both functional and aesthetic. It will allow you to clench the pipe more easily (if you choose to do so). It's your pipe, but to "pipe guys" it just looks wrong. Not a big deal though since you weren't exactly following the rules when you made that.nightserpent wrote: Wayne- are you suggesting a downward bend for aesthetic or functional purposes? If the former, I'm guessing it would be to make an S-curve? I thought it might be beneficial to be able to see more of the bowl when it is being lit.
Yep. What Ernie said. Typically and generally speaking you want to aim for the end of the stem being slightly above the parallel plane with the top of the bowl if that makes sense.
Also, a slightly rough surface in the tobacco chamber can help give carbon a surface to cling to so a proper cake can be built up. You'll find varying opinions on how that chamber walls can be prepped and finished.
