I finished this pipe yesterday afternoon. It is too big for my liking, makes my head look small... but as always, I enjoyed making it and I look forward to your comments and critiques.
Thanks,
Kiel
billiard for critique
- Literaryworkshop
Re: billiard for critique
Well, I can't say much, but I'll start. I think the overall shape looks pretty good. There's a nice taper on the bowl, and the proportions look correct, if not totally spot on. I wonder if the stem is just a tad too long? Also, did you drill the bowl and airway at 90 degrees to each other? I think the most visually pleasing billiards usually have the bowl canted forward ever so slightly.
- Steve S.
Honestly, I have no idea. I try to angle it forward slightly while drilling but I cant say to what angle. I also find it really hard to square up a block before i drill. If it looks square enough i'll go ahead and drill. At this point in my process, I am lacking percision.Literaryworkshop wrote:Well, I can't say much, but I'll start. I think the overall shape looks pretty good. There's a nice taper on the bowl, and the proportions look correct, if not totally spot on. I wonder if the stem is just a tad too long? Also, did you drill the bowl and airway at 90 degrees to each other? I think the most visually pleasing billiards usually have the bowl canted forward ever so slightly.
Thanks for the feedback!
Kiel
Not bad at all. Shaping is close. Looks like you took a tad too much on the heel and back side of the bowl and the heel lifts a bit too soon. Stem length looks good and proportions look good. Button and slot work needs some refining. It looks like your airway ends a little low in the tobacco chamber. You want the bottom of your airway to be pretty close to the bottom of the chamber. I drill my chamber just a fraction lower to account for bowl coating.
I will make sure to pay more attention to the drilling on the next one. Honestly, chamber depth has always been a bit confusing to me. I have a Stanwell where the airway is really high in it. It is like a trench in the bottom of the chamber. I thought the pipe smoked fine, but I have never smoked a high end pipe either.wdteipen wrote:Not bad at all. Shaping is close. Looks like you took a tad too much on the heel and back side of the bowl and the heel lifts a bit too soon. Stem length looks good and proportions look good. Button and slot work needs some refining. It looks like your airway ends a little low in the tobacco chamber. You want the bottom of your airway to be pretty close to the bottom of the chamber. I drill my chamber just a fraction lower to account for bowl coating.
When I am drilling the chamber I don't go for the "trench" look, but I am also afraid of over drilling it. I would bring it to where I was comfortable with a "far enough" depth.
I appreciate your feedback on this pipe and the tomato I posted. I have been finishing up some old pipes this last week. After I get those done, the advice I have gotten on my last two pipes I will try really hard to put into practice.
Thanks,
Kiel
