Hi everyone,
I was recently talking with a pipe-making friend in Russia and he showed me a very nifty hand chuck that I can't find anywhere here in the states. The one I currently use is more like a pin vise and you tighten it by hand, but I can never get it tight enough, and the keyed chuck on this thing looks like exactly what I need. The chucks on the ends come in different sizes as well! Anyone ever seen anywhere local I can get this, or should I start perusing Russian tool websites? I can't find anything on mcmaster-carr, msc, enco, etc.
Thanks!
Besides Russia where can I get one of these?
Re: Besides Russia where can I get one of these?
Buy a mini chuck and mount it on a handle.
Shouldnt be too diffucult to make your own. Buy a threaded back chuck and appropriate bolt, cut the head off. Drill a hole in a handle and epoxy one end of the bolt, then screw on the chuck. Simples
And here I was thinking that there was one tool that could be used for pipemaking that I wouldn't have to make myself . The screw-on chuck idea is good, but I need to be able to twist the handle in both directions so that may be a problem. I guess I could just turn and knurl a piece of steel rod and turn a JT taper on one end. Hmm...
Why do you need to turn the handle in both directions? If you get a keyed or keyless chuck the handle can be fixed solidly. This one at McMaster fits a standard hex handle.
http://www.mcmaster.com/#drill-chucks/=95armn
I've taken one of an old Black and Decker drill that I use to hold stems (by the tennon) when working on them.
David.
David.
General Tool makes the American version which is available from hardware stores and online sources:
http://www.midwayusa.com/viewproduct/?p ... ber=953047
I have an older model made either by Goodell-Pratt or maybe Millers Falls. Useful.
He's specifically looking for one with a keyed chuck; this one is keylessDavid Barnett wrote:General Tool makes the American version which is available from hardware stores and online sources:
My bad!
Yeah, my old handle chuck is keyed, of course, and I completely missed the point. They say the mind's the second thing to go. And to think I de-cloaked from lurk mode just to post that helpful tidbit.
All I can offer is that I come across these occasionally from sellers of old tools online and otherwise.
