Yesterday wanted me to develop a classical pipe. It is a thin-walled Lovat, 30 grams, and a capacity quite respectable.
Ayer me apeteció elaborar una pipa clásica. Se trata de una Lovat de paredes finas, de 30 gramos de peso, y con una capacidad bastante respetable.
Lovat "PF"
Lovat "PF"
El mundo de la pipa
Re: Lovat "PF"
Hi Félix,
real nice pipe, great!
Peter
Peter
Pipe-Blog: http://daskunstportal.at/artofbriar/
Drawing-Blog: http://daskunstportal.at/8bar/
Forum: http://www.daskunstportal.at/pipemaker/index.php
Re: Lovat "PF"
Peter:
Glad you like it.
Peter:
Me alegro de que te guste.
Glad you like it.
Peter:
pereu wrote:Hi Félix,
Peter
El mundo de la pipa
Re: Lovat "PF"
Very cool. Long shanks like that are hard to do. You pulled it off perfectly. Good job.
Re: Lovat "PF"
Very pretty pipe. The only thing that hits my eye in a negative way is the saddle portion of the stem. If you were more aggressive with the curve making it more steep and less sloped I think you'd achieve the saddle look a bit better which would make that part of your stem look more like an extension of your shank.
Basically, whatever tool you used to achieve your curve or slope, maybe find a smaller one and go at it again.
Just a thought though.
Brian.
Brian.
Re: Lovat "PF"
Brian:
Next time I will.
I guess you mean something like this:
Thank you.
Brian:
La proxima vez lo haré.
Supongo que te refieres a algo así:
Gracias.
Next time I will.
Thank you.
Brian:
Gracias.
Growley wrote:Very pretty pipe. The only thing that hits my eye in a negative way is the saddle portion of the stem. If you were more aggressive with the curve making it more steep and less sloped I think you'd achieve the saddle look a bit better which would make that part of your stem look more like an extension of your shank.
Brian.
El mundo de la pipa
Re: Lovat "PF"
Hi,
that is a very beautiful Pipe. I like it, this is one of my favorite shapes.
Great work.
Greetings Tommi
Great work.
Greetings Tommi
my English is bad
