Hi there,
I screwed up this one immediately when drilling (the mortise goes right through into the tobacco chamber),
so it was clear from the beginning, that this would be a shop pipe, and good for surface experiments - so please ignore the crappy stem and the even crappier stem - stummel junction ...
Acrylic stem, 8.5 cm / 3.35 " long, weight 50 g / 1.77 oz.
Critique, please ...
Jens
winter wren 2
Re: winter wren 2
Too bad about the drilling. This one has a very interesting texture. I'd be curious to know how you achieved it. Keep up the good work.
- bandkbrooks
Re: winter wren 2
I really like the colors on this one. It's almost a patina copper look. How did you do it?
Brandon
Brandon
Brandon Brooks
Brandon Brooks
Brandon Brooks Pipes
http://www.brandon-brooks.com
Brandon Brooks
Re: winter wren 2
Hi,
Thanks for your comments!
I brushed it with a wire wheel on my dremel - stained black - brushed again - stained green - brushed again - applied sanding sealer - brushed again - polished with a felt wheel on my dremel.
Sounds complicated, but takes less than half of the time for a good smooth surface ...
Jens
Jens
- bandkbrooks
Re: winter wren 2
Is a sanding sealer safe to use?
Brandon Brooks
Brandon Brooks
Brandon Brooks
Re: winter wren 2
Sure. Shellac is a sanding sealer.bandkbrooks wrote:Is a sanding sealer safe to use?
Re: winter wren 2
What I use, is actually this: http://uk.opitec.com/opitec-web/articleNumber/660028
Works like a charm ...
Jens
Jens
Re: winter wren 2
Sorry it got fouled. It's kinda interesting though. Reminds me of a bird. A wren actually.
Re: winter wren 2
Really interesting finish. I like it. Good experiment!
Iñigo.
Iñigo.
- bandkbrooks
Re: winter wren 2
@Rad. Thanks. Big duh on that one.
Brandon Brooks
Brandon Brooks
Brandon Brooks
