Sea Horn
Sea Horn
This may be the ugliest pipe I've ever made, but in this case I wasn't trying to make it pretty. I wanted it to look like something you might pluck out of the deepest parts of the sea where the underwater volcanos shoot hot gasses and only the oddest creatures live.
Hmmmm...maybe I've been watching too much Discovery Channel lately
Anyway, here is my Sea Horn. It should probably be called a Sea Dublin, but that just doesn't fit.
Thanks for looking.
Brian.
Thanks for looking.
Brian.
Re: Sea Horn
LOL. It totally helps. Now I know I should take it outside, smash it to bits and burn those bits to ashes... and burn the ashes again just to be safe.Sasquatch wrote:That's gross.
Hope this helps.
Sas.
Thanks.
Brian.
Re: Sea Horn
I just did some spear fishing last week and this pipe definitely looks like something I would have seen there in the reef. Nice job, Brian. I always enjoy looking at your pipes, man.
Re: Sea Horn
Love the color, and the "bubbles"! Great pipe!
Re: Sea Horn
Ok, Brian, let me tell you what I like and what I don't like. For starters, nice flow. The bit work also looks phenomenal. I really had to stare at that button for a while before I decided that it looked near perfect.
Now what I don't like. First, what is that indention on the rim? It seems out of place and doesn't look like natural plateau. Second, what's up with the little circular rustication marks on the stem and the shank? I think that if you wanted to rusticate in that fashion it should be the whole pipe or none at all. Just my 2 cents.
It definitely has an organic feel to it, which is good because I think that is what you were going for, and, judging by Sas' reaction, this is a pipe that does illicit an emotional response. That counts for a lot in my book.
Re: Sea Horn
Yeah, I knew this one would be about a 50/50 response. I'm not even sure what I think of it. I would have loved to have a perfect plateaux on the top, but the block had a major flaw so I "worked around it". I LOVE symmetry and consistency, so this pipe goes against a lot of what's built in me. It's a good exercise for me to make stuff like this that makes me lose the symmetry for a while.
The circles on the shank, I thought about making them go across the entire thing, but I wanted both smooth "petals" and rough shank. I gave it some thought and realized that nature isn't always one texture from top to bottom, and since I was trying to produce something "natural" it was ok to have both. Once again, this was a stretch for me.
I like hearing people's thoughts on it though. It's fun to see what people think of such a thing...
Brian.
Brian.
Re: Sea Horn
I would be proud to have that in my pipe rack. I think it's unique and amazing. Personally I really like the circles as it adds a bit more to the effect of the entire pipe. But to each their own :p
Re: Sea Horn
From the bottom it sort of reminds me of a horseshoe crab. Dont know why, I guess the way the plates of their shell move.
Ryan Alden
http://www.aldenpipes.com
Re: Sea Horn
I actually thought about that too. It reminded me of a lobster a bit when it was finished. I definitely want it to look like it could move, scrunch up. I almost called it "Crustacean" .Edward wrote:From the bottom it sort of reminds me of a horseshoe crab. Dont know why, I guess the way the plates of their shell move.
Re: Sea Horn
I really like this. It's an abomination and I don't care. If it weren't quite so bent I might call it a tube worm. There's a couple critters that hang out near volcanic vents that resemble this thing.
Andrew
www.andrewstaplespipes.com
Re: Sea Horn
That's exactly what I was thinking of when I made it. I also thought about "sea worm" but my wife killed that idea. I also thought about "crustacea" as it almost looks like a lobster sort of thing.andrew wrote:I really like this. It's an abomination and I don't care. If it weren't quite so bent I might call it a tube worm. There's a couple critters that hang out near volcanic vents that resemble this thing.
Maybe I should just make billiards so I know what to call them
Re: Sea Horn
I'm glad you can get to whatever place that design came from. It is nearly impossible for me to pull that kind of thing off. Then again, I'm an engineer, so I'm lucky just to have a personality.
Andrew
Re: Sea Horn
LOL. So do you draw your pipes up in CAD? I'm more on the artistic side of life I guess, which helps in funky designs, but doesn't help when I'm trying to figure out how many millimeters to turn my lathe handle to get to the correct diameter on my tennonsandrew wrote:I'm glad you can get to whatever place that design came from. It is nearly impossible for me to pull that kind of thing off. Then again, I'm an engineer, so I'm lucky just to have a personality.
Re: Sea Horn
Naw, I'm not that bad . I don't sketch as much as I used to. I usually just get an idea now and do a rough sketch so I don't forget what I'm trying to do halfway through the pipe.
Andrew
Re: Sea Horn
It's ALIVE!! It is unique. It's original. It's very creative. It really does seem to be capable of animation. And it only takes one buyer to make it a successful venture (but not me, sorry).
Sea Worm might be a little too literal; perhaps a proper name, maybe Harold or Ralph.
Still, congratulations on a terrific conversation starter. ("Is that a sea worm in your mouth or are you just glad to see me?")
Re: Sea Horn
I love it. It is original and well done.
And for the record I am an engineer and, yes, I draw my pipes up on CAD before making them.
