I always wanted a reverse calabash pipe. it is just too good to be passed.
A few days ago, I was hit by 'a nature bullet' (cracked briar),
http://www.facebook.com/zhanping?sk=wall
But thanks to that, I can make some experiment.
I make the briar into a Reverse Calabash Billard with some rustication(which i never tried before. )
Here are some photos, and please let me know what you think.
#0016 Reverse Calabash Billard
Re: #0016 Reverse Calabash Billard
Oddly disturbing. Quite a clever save, really, but I would anticipate some market resistance demanding significant advertising revenues in order to establish a beachhead.
Hudson wrote:Oddly disturbing. Quite a clever save, really, but I would anticipate some market resistance demanding significant advertising revenues in order to establish a beachhead.
Well Reyvagin is doing it... I have the feeling it wont catch on.
Ryan Alden
http://www.aldenpipes.com
Very, very original.
Muy, muy, original.
Muy, muy, original.
El mundo de la pipa
Pretty cool. For some reason, I wish the briar inside the chamber was stained.
I think it's awesome, Ping. Mind if I tinker around with the idea at some point?
Yeah, this design may not for everyone.Alden wrote:...
But I think it is more for the functionality, and also looks cool with some fun or just a laugh.
Thanks.maxmil wrote:Very, very original.
Félix....
Thanks, maybe i will stain it next time.UberHuberMan wrote:Pretty cool. For some reason, I wish the briar inside the chamber was stained.
Wayne, thanks and I don't mind if you make your own version of it.wdteipen wrote:I think it's awesome, Ping. Mind if I tinker around with the idea at some point?
Actually, the idea was borrowed from the master Reyvagin.
Do whatever you want and have fun.
Ha, another pipe maker using glass. This is what I like to see.
How does that joint hole up when you smoke it? Glass on wood joints have been a bit of a trouble for me.
It seems as though wood will wear quite quickly against glass, and the joint becomes loose.
And since glass and wood expand differently, that could be an issue...maybe.
Or is that acrylic? ha.
Also, how do you find this effects the smoke? Do you think that the cool surface of the glass (if it is glass) condenses moisture well?
it is acrylicmeathod wrote:Ha, another pipe maker using glass. This is what I like to see.
the joint is fine. the structure is similar with army mount. that means i cut an angle on the stem and inside the tube.
I haven't smoked it yet, but i will let you know how it smokes.
