I am a hobbyist that is trying to get better
I am working with kits now, I have a drill press, and spoon bits, will get other tools as I need it. Also have the bench top belt sander. I will look around for more information, I will especially need lots of learning on how to make nice stems.
Here are some of my pipes, they are pretty bad photos as I have a condition that makes me shake when trying to hold still
this is a very large fan pipe I made for a friend
This is a freestyle church warden with burr rustication
This is my own pipe, a fan style pipe that feels really good in my hand
And this is a "web" pipe
Ok, please be gentle
rev
first post
first post
Re: first post
Hey rev, not bad at all. It looks like you're having a good time making those puppies! The web pipe is pretty neat. Try to get your stem face and shank face flush and you'll improve your pipes a lot.
Re: first post
I like the last one I am very impressed
Longneckers
Longneckers
Re: first post
looks good!
I play the bagpipes, heck when I started they said there were only 9 notes on a bagpipe. I said how hard can it be? lol
Re: first post
I think working on the engineering aspect(seamless stem junctions) is a great tip, you seem to be capable of some more complicated shapes for sure. I would suggest visiting a more classic shape, I think practicing something tried and true will actually help you innovate better. My other thought, is how are you applying your finish/ what is it?
Re: first post
X2. You can make as many crazy and freehand shapes as you want, once you master (or at least understand) how to make a quality classic shape. It will help you a lot with your stem problems, shaping, drilling, and finishing (basically, everything).The Smoking Yeti wrote:I think working on the engineering aspect(seamless stem junctions) is a great tip, you seem to be capable of some more complicated shapes for sure. I would suggest visiting a more classic shape, I think practicing something tried and true will actually help you innovate better.
On top of the benefit of practicing a known shape, you will also get much more helpful critique since there is a more canonized standard for grading/quality of classic shapes.
Re: first post
I was under the impression that the classical shapes were much harder to do without a lathe, which I don't have yet. Is this not true, or is the idea that it is harder? Can I make a bulldog or billiard with just a bench sander? I will take your advise, just wondering. And can I make my own pipe stem without a lathe?
As to my finish I am taking it up to 400 grit sandpaper, then I use Mohawk alcohol penetrating stains. Sometimes I will resand a time or two an apply another color over it. I will use a black stain for rusticated spots or the top burl. Then I use wax and buff it out.
I will look around for more tips on how to do things better, but please feel free to continue to critique.
rev
rev
