#9 - Not Sure How I Feel About It
Cory
Post by Cory »
Any tips on making the yellow contrast look less yellow?
There were some issues with the stem early on so that is why there is a slight gap/misalignment.
Re: #9 - Not Sure How I Feel About It
Sure. Use orange, red, or brown. :lol:
Seriously though, you might try adding a touch of brown to cut down the brightness of the yellow. It shouldn't take much.
Hudson
Post by Hudson »
Have you tried wiping it down with alcohol? Wet sanding with alcohol, then wiped? That should mute it some.
