Halloween
Re: Halloween
Probably not on purpose Maybe if I mess one up bad enough, I'll change my marketing and call it a Halloween pipe
Re: Halloween
Okay, who's seen Trevor's pipe yet?
ABSOLUTELY NIGHTMARISH (in a good way!)
I personally think you're undercharging, Trevor.
Re: Halloween
So I was thinking about making some Halloween pipes this morning. Nothing even close to as elaborate as Trevor's pipe this year, but something a bit more easy to make.
I figured a couple of heavily rusticated billiards with a red and black finish and a jagged rim could pass for a good Halloween pipe. Just something simple I could make to start learning how to use my lathe.
Back when I first got started I carved a Jack O Lantern pipe from one of my first kits. turned out pretty well actually. Back then I had the idea to make a seven day Halloween set with each pipe based off a Halloween character or theme: a vampire pipe, a pumpkin pipe, a mummy, a frankenstein, ect. and then box them up in a small coffin presentation case.
Any thoughts?
Any thoughts?
Re: Halloween
That would be pretty cool. You could carve some pretty awsome blood suckers into the vampire pipe. Hell, I'm scared just thinking about it
Re: Halloween
Something like this Oce?
http://www.talbertpipes.pair.com/goblin ... 205g.shtml
Hello, I'm #1312.
That's a really big number.
